Emergency DEF bypass
WinePress
I saw a post, can’t find it now, that linked to a website that laid out a kit to build that would bypass the sensor issues. Can someone direct me to this? I’d like to have one in case I get stranded on my journey to Hawaii.
Thanks in advance……
To do this right, it’s not cheap. Additionally, the components can be hard to obtain currently.
Depending on your DEF system, I may be able to you a DEF Head Emulator from Custom Coach Products.
Feel free to drop me a DM and I’ll get info from you.
defsim.myervin.com
RB’s link is correct ( DEF Sensor Simulator ), its about $150 to build, but it will only work on 2016 and later chassis (my 2016 coach is on a 2015 chassis so not compatible) and as designed, it is only compatible with Spartan chassis coaches and some Tiffin (Powerglide chassis?) models with solid-state DEF level, temp, and quality sensors.
To make it work with 2016 and later Freightliner coaches you have to acquire the correct 4-pin (CAN-bus) connector (now also detailed on the website).
Pre-2016 Freightliner coaches have a float for sensing DEF level and the signal can be emulated with the correct resistor, but I don’t have that information readily available. Easy to figure out though (see TSB below).
So while an excellent adjunct for compatible units, its pretty limited. It also only overrides the sensors in the tank, so you still have to run DEF or you will get SPN codes from your SCR telling you your NOX levels are too high, and still be derated.
Also it appears that as of around late 2020 Freightliner DEF headers (TE connectivity) nearly eliminated the false low DEF failures. DEF heads from Shaw Development used in Spartan and Powerglide chassis are said to be more reliable as of Gen 7 but that remains to be seen.
So to get a more specific answer on what you can do both as preventative measures, and for contingencies, list your coach chassis year, make, and model. But don’t just buy the parts and build the DSS without confirming that it will work for you.
There’s a lot you can do on your own to increase the reliability of your coach and your confidence in your emissions system. I’ve had three parts failures resulting in derates, but my last trip (7700 miles) was completely emissions-trouble free. Had my share of other issues, but not a peep from the emissions side.
This TSB: https://static.nhtsa.gov/odi/tsbs/2013/SB-10054667-8295.pdf has a lot of useful information on keeping your system working and correcting problems, and includes the correct resistance reading for pre-2016 DEF level sensors if you want to go that route.
Thanks for everyone’s input. I’m on a FL chassis so I will do more research on the adaptability from the Spartan connector to the FL. I did disconnect, clean and reconnect all the connections, including the PCM. Problem cleared, but I would like to be proactive with a solution to solve a potential non drive issue.
I do not want to delete the def But.
I do want to Find an emergency Is temporary bypass That will allow me to get home To my mechanic. I use my van for work and often many states away From the house and don't want to get stranded on the road
Since you didn't mention what yr your coach is, you may not need one. The problems are with the coaches that have digital systems, not with the analog systems.
If it's the temp switch, (probably not the correct name for this part) and it generally seem to be, you can put a clamp on the intake/return hoses to stop the flow of hot fluid from entering the def header. Once everything cools down and the error clear, you should be OK to proceed.
This is the most common problem with pre-2016 emissions: https://static.nhtsa.gov/odi/tsbs/2013/MC-10142383-9999.pdf.
Anything with DEF can leave you stranded if you don’t understand the system and/or are not prepared to correct problems as they occur.
That said the DSS will not work on pre-2016 emissions for the reasons Roadglide stated.
I have a good friend, electrical engineer, has built dozens and sold them to a lot of Newell owners. In fact, his head just went out on their trip to Florida last week. He was back up and running quicker that it took his wife to go get a couple sandwiches! ;-)
His units are $600.
DM me of you’re interested.
As I mentioned, the DEF EMULATOR does NOTHING to delete anything. It merely bypasses the warnings to allow you to drive to safety without the fear of a derate. Once you replace the head or whatever, you remove the Emulator and your 100% back to stock and can store the Emulator for the next time. 😉
His units are $600.
$600 his profit margin is built for the Newell crowd lol...
I am going to try to build one of the Bypass units following available instructions above. Looks relatively easy to construct, the programming and compatibility/operation with the Spartan Chassis equipment might be the hard part.
I purchased one just to have in case from K1 Technical.
Around 275.00 + shipping.
very easy to put together and probably $40 in parts
They cost me $30 to build. The guy selling for $600 sounds line a crook. I developed the firmware and made it freely available to folks with a non commercial license. If i was interested in making money I would be taking legal action against him and others.
Why be upset about someone’s pricing?
If too high and it isn’t a monopoly, then just buy elsewhere. Market forces will bring balance.
Because he’s selling my intellectual property that I offer to Owners for free. He has no right to sell my IP. If folks want to change folks $75, I’m fine with that since it does take 10-15 minutes to build one.
