FYI Disaster Strikes
Joe Dutchstar
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
Well we were up at 4:00 heading to Orlando for a 7:30 appointment at Cummins to address the final coolant leaks. Pulled the Coach out and the garage door refused to close.
I thought it would be easy to manually close the door, NOT. Door jammed about 2/3 way down. Now I’ve got the door partially opened and the bus in the roadway! Now what!!
Started texting the property manager around 6:00 am. Everyone should be at work by 6:00, Right!
By 7:00 I started getting responses. Called the Door Vendor who showed up at 11:00.
Door is finally closed but inop. New parts on Monday.
Found a place to park the RV out of the way.
Moved the Cummins appointment to Tuesday.
At least it didn't get jammed with the coach in the garage...
Yes there is always a bright side🤣
What broke to jam it up the springs?
Bill
It appears a cable holding one side of the door became undone. This racked the door as it was being manually lowered.
Those big doors typically have 2 springs. It still could've broken the side that came unwound. Those cables are TIGHT!
They say garage doors always break in cold weather, hope everything goes well with the coach repair.
Luckily the garage door was repaired under warranty. Quick service.
Cummins on the other hand is slow walking looking at the RV. Been a week, after numerous calls (do not like the RV sitting in an urban parking lot), they say maybe today, Friday the 31st. Dropped it off on Monday, this week.
According to the Cummins manager there, it is NOT first come first serve. Though I did see many First Responder vehicles, Fire Trucks, etc. in their lot. Clearly First Responders would have preferential service. No issue with that scheduling.
Maybe next week to determine what the problem(s) are determined to be.
