- Dec 19, 2019
- Dutch Star
- 2026 Willys 2 door XR
Thanks Ed, I was beginning to think I had acquired a curse of some sort. Now, to tackle the Oasis, Active Air, shade motors, etc.....Congrats @lostinfla , I know the feeling.
What is your AA problem?Thanks Ed, I was beginning to think I had acquired a curse of some sort. Now, to tackle the Oasis, Active Air, shade motors, etc.....![]()
I did this when I did my lithium conversion. I was flabbergasted that Newmar didn't include it from the factory. Battery positive to kill switch then to positive bus bar for the other loads connect to. Makes maintenance and storage so much simpler.I have often debated adding another battery kill switch for all things that bypass the main chassis battery kill switch(es -- if Spartan) that they wire in at the factory.
Right rear bag gains pressure while driving. I have to keep switching the RR from low to normal to keep the pressures close to normal. Been going back and forth via email with tests they suggest, but it's looking like a trip to Moscow this year.What is your AA problem?
That’s about the only place that can help you, unfortunately. I’m 2000 miles one way from them which makes it somewhat troubling. Once there, however, they are good, fast & relatively inexpensive to deal with.Right rear bag gains pressure while driving. I have to keep switching the RR from low to normal to keep the pressures close to normal. Been going back and forth via email with tests they suggest, but it's looking like a trip to Moscow this year.![]()
