Floor replacement advice?
mcd244
I am removing the carpet in our class a motor home and want to install vinyl plank flooring. Any opinions on using this flooring. I installed it in a small travel trailer we had and it worked great but this is a much bigger floor than that. Thanks for the help.
It's a shame @MapNerd isn't around any longer (sold his coach) but he did this. Try searching the forum as he posted his install. Did a great job.
We replaced the rolled vinyl/carpet on our first mh with the vinyl plank and loved it. If you have damage on the floor you can just replace one plank.
We had a few soft spots I thought might be root, but found out they used foam as support and the foam began to collapse over time. So in those spots we used conventional plywood instead of the wafer board.
Looks great, thanks for the pictures. I will let you know how it turns out.
