Had a surprise when checking 365/70 R22.5 tire date codes
JRS
Full timers
Dutch Star 4328 - FL Chassis
2018 Jeep Grand Cherokee
Purchased rig in Aug 2019 and did a factory pickup in Sept 2019. I've been under the rig before but never checked the date codes (didn't think I had to) until yesterday. To my extreme disappointment, one of my 365 drive tires had a date code of 2318 and the other 4818! Why the 25 wk difference who knows but one will be 7 yrs old this summer. Could only read half of the rear tires and all were made in early 2019 ( 2 have 0919 other 0519). So..... I suggest those with a similar aged rig to check their 365 tires (only Michelin makes the 365 RV only tire).
Because the tax rate is more favorable in Dubuque, IA compared to other places we'll be later this yr (getting front seats recovered at Bauer RV Upholstery) I gave Bauer Built Tire & Service a call (company has a lot of locations). Jimmy the Mgr is a great guy. He actually suggested I don't get the tags and drive tires done yet and that many run till 8-10 yrs. They're "virgin tires" and if they do blow out, they'll typically blow out from the sidewalls which will not typically cause that much damage. He'll check the rear tires when we get the fronts replaced. He carries Continental tires but suggested B.F. Goodrich which has the same casing as a Michelin and will ride softer than the Continentals. They spin balance and worked with many RVs with Alcoa Dura-Bright coated rims. Said to call 5-6 wks ahead to schedule the appointment. Because the tax rate in nearby Plattsville, WI is 5.5% I called a dealer there and haven't received a response call.
Fortunately all my tires look great and couldn't find a single crack anywhere, bulge, etc on the reverse "unexposed" side of the tires. Now knowing my drive tires are 6.5yrs old, I'm now a firm believer in McKee's 37 Gloss Tire Gel which I've been using for years (don't cover the tires). The outside of the tires look like new.
My 2₵ observation is Jimmy is giving you some poor information. Those drive and tag tires may run 10 years but they may not run 7 and if and when they do blow the tire coming apart is going to cause damage and usually severe damage. Let's not even consider if and when the tire blows you could lose control of the coach and cause catastrophic damage. Oh, and ask Jimmy about zipper blowouts. Michelin gets that award primarily due to their sidewall construction.
Well sorry, I probably gave you a dollar's worth.
Yeah I agree with the dollar lol
Wanted to keep the post from getting too lengthy.....
Jimmy did agree that the steers are at the time to consider replacing but also said he'll change the rear tires if we want but at less than 6.5yrs old he'll inspect them this summer. If they look good like I told them they do he suggested we could get more time out of them. We were ready to replace the rears but he actually unsold us on replacing them at this time!
The tires look great so I'm going to get more time out of the rear tires. There's a bit of scuffing on the tags but not a single defect on either side or treads of the tires that I could find. Here's a picture of the rear tires I detailed last November and they still look like new. Oh.... my exposed side steer tires look as good as the picture below
I am of the camp that wants to keep tires going while they still look good and have regular inspections.
We just replaced all our tires at 8 years old, only because we WERE going to sell the rig, but changed our mind and decided to keep it.
At 8 years old, outside and inside (checked insides after they dismounted the tires), upon CLOSE inspection, the tires were in great shape and believe we would have reached 10 years without any issue.
Happy to see your tires are doing well!
Cool! Thanks for the post. Which brand did you have and which brand did you switch to?
We had Michelins and now have Toyos.
Always tough to compare old tires with new tires, but these new Toyos are riding softer and quieter than our old Michelins. So far we are liking the Toyos but time will tell.
I did the same and given the price disparity I couldn't be more satisfied.
Toyo's for me too. While tires may look good, I'm not going to risk it. An accident at highway speed is not something I ever want to experience. I'll gladly do Toyo's every 7 years or rotate out steer (front) tires at the least.
My 365 Michelins looked great at seven years, right up until that tiny little bulge showed up on the driver side. Immediate replacement showed more bulging on the inside of both front tires, making for a very grateful driver. (What a great time to have Casey Tubman standing there, shaking his head in disgust because I waited so long to spring for new tires!)
He could have just bought them for you because you're a cool guy! Come on Casey!
