Dead fridge
SGilbert
South Bend, IN
Thor
Axis 25.2
Ford E450
Ford V10
2006 Honda CR-V
Just learned a new trick.
Our POS Norcold fridge would not ‘fire’ up and after checking all, I decided to check the fuse.
Pulled it, looked good so replaced it. Voila!!! It now works.
Saved our 2 week trip!!
What i believe I did was reset the control board.
Additional info:
I just returned from a 2 week trip, and the Norcold would not start.
My 'trick' failed me this time. After piddling & fiddling for over a day, I switched to "Gas" (propane).
Still no go, and heard no piezo clicks.
I took my lighter stick and tried to light the flame.
Voila!! Heard the slight 'hiss' of flame. Returned to inside, and the light was finally solid.
After a few hours, the fridge was cold and the freezer icy!
Many days passed with 70+ mph, strong winds, semi's passing with their wind gusts and swirling tail winds, and driving rains---the light stayed solid and never quit until I turned it off 13 days later at home.
Not sure what my next step will be, but if manually lighting the gas once/trip works, I'm tempted to just go that route.
Check the pilot light chimney. Scale from the chimney walls will flake off and drop to the bottom inhibiting pilot light ignition. Use compressed air or a vacuum to clean.
Additional info:
I keep hoping @Neal Will put a thumbs down on the forum.
to me one light per trip means "UNSAFE AT THE PUMP !" I hope I misinterpreted your post.
FWIW, the fridge is on the passenger's side and the gas fill is on the driver's side!
Yup! Tell that to patty's propane in Quartzsite.
Yes! In the past 2 months.
Not the only case I can verify, but then I'm just a kid.
Then tell me what everyone else (not you) that runs their fridge on propane do when they gas up?
I shut down everything when I gas up and when I get Propane including Generator, Fridge, Water heater and the water pump. My life is a lot more valuable than having a stray spark, let alone an open flame, any where near where there are flammable vapors. Sorry, but I hope I never meet you at a service station.
A pilot light on a propane fridge at a gas station is like playing Russian roulette! A game I'm not willing to play. Our propane fridge and water heater are always turned off before driving and not turned on again until we've reached our destination. Our lives are worth more than spoiled milk.
That fire had nothing to do with a pilot light being on. It was caused by a person dropping a propane cylinder.
Quartzsite propane fire starts with dropped cylinder​
Although many of Quartzsite’s snowbirds had already left town, there was still business to be had on that Tuesday. A man rolled up to the propane outlet in a van. It’s reported that a propane cylinder he was carrying in the back of the van had fallen over. When he opened the door to fetch the container, it fell out, striking the pavement then exploding. The customer was seriously injured and had to be taken to Phoenix for treatment.
Major update:
Long story short, I have been having trouble for almost 2 years with my Norcold fridge either not starting, not staying lit, Only running, when it does, on propane, not AC. I left home for a 10 day trip with a working fridge, but at the 1st gas up, it was out and, no matter what I did, it would not light! I asked Siri for a recommendation, and after calling, found a dealership in Davenport, IA that would take me in. Damn the price, this POS had to work!! After 2 ½ hours, the quarter sized 2 connector on the "stack", thermal switch, was the culprit. It was intermittent, though. Tech cleaned it up, but said the part needed to be replaced but they didn't have it. 2 days now, it's working. He gave me an UNOFFICIAL hint, if it dies, to plug the 2 wires into any size auto fuse; bypassing the safety feature, but outsmarting the fridge!! I highly recommend Campers Inn of Davenport! They have saved my trip, worth any amount!
I always have a couple of inline fuse holders in my tool box for on-the-road temporary fixes.
That used to be my attitude until I got absolutely lambasted by everyone else here.
I keep my propane off at the tank unless actively camping and using it.
Have always operated this way, even when I had the TT and a propane/electric fridge.
I don't recall ever losing any food between campgrounds.
