Televator TV upgrade
Buly
RVF 1K Club
TGO Titusville FL
InTech
Dawn travel trailer
Aluminum
Lexus GX460
I have been itching to replace the original 46” TV with a 4K 50” model. By my measurements it will fit? They sell now for under $400.
The big problem is fishing a new HDMY V4.0 60 HZ cable.
I have no idea if it is even possible? If anyone has an idea, I’m all ears ?
Go for it. Report back! :) If I am replacing any TV's they'll be Samsung QLED.
If you buy two, and give me one, you may get a better deal :LOL:
Please reply with credit card number. Is it a MasterDebt of Visa?
What’s the problem? How to go about it? If it were me, I’d just take some twine and tie one end my new cable to the end of the old one, then go to the other end of the old cable and get to tugging. Pulling out the old cable will feed in the new.
I thought about it John,
But with my past experience working on the coach, they most likely have tie wrapped the cable in few places?
I had to replace the TV antenna control box by the passenger . It comes with 6-8” pig tail with two coax connectors.
The TV technician gave upand told me “ I can not get to the connectors without cutting the wall” and left.
I got my borescope, and found connectors tie wrapped to the aluminum beam down inside the wall.
I fixed it, but also run out of curses for the idiot that did it.
Is your elevator in the front, passenger-side slide-out? Ours is and the receiver et al are in the cabinet above it. If yours is like ours, the HDMI cable can't be very long. I'm guessing that if you remove the HDMI wall plate, the cable is probably just drops down to where it enters the televator compartment. When you have the old TV out, you could have room to easily fish a new cable in.
TJ,
Wish it was that easy. The AV cabinet is above the driver’s head, and Televator is behind the sofa on the passenger side between the kitchen and passenger seat. I’m guessing I will need about 20’ long cable?
TJ,
OK; your coach is different from ours. Would a wireless HDMI extender bridge the distance? I'm not much of an electronics geek, so that might not be an option either. Might be worth a look, however.
I thought about the wireless idea, but I’m not even sure if it exist such a thing? Will have to ask Google ?
Thanks TJ,
If the cable idea fails, I will go wireless. Now I will shop for motivation ?
From what I read in this article, it is very likely that the existing HDMI cable may work for basic HD TV. No gaming etc.
4K HDMI cables (are nonsense)
here is the key:
. Most cables purchased after 2009 are High Speed and will pass a 4K signal to your screen.
I couldn’t understand initially why Newmar would zip tie the cable, but now knowing that your AV cabinet it above the driver (weird?) I can kind of understand why they might.
that in mind, the best I could think of other than TJ’s wireless HDMI is an endoscope with a clipper attachment. Seems like the existing cable would probably work fine though.
Don't worry about the HDMI cable. An improved TV will look great. You can connect an Apple TV to it directly via your own HDMI cable if you wish to get real 4K streams assuming you have a good enough connection. You're likely not getting 4K over satellite or OTA so where is your 4K source coming from requiring any different cabling?
You are right Neal. Turns out, I have to get from Dish a 4K receiver also for about $140.
I don’t think any wifi or Cel Service while traveling is good enough for 4K?
I'm not aware of DISH or any other SAT service offering 4K. That's news to me. I didn't think SAT's could handle that bandwidth.
Yes, WiFi/Cell can do 4K fine but it's a lot of data. If you get an Apple TV 4K like I have which is all streaming you can go to YouTube and find 4K videos and enjoy them. 1080p is fine, you likely will not realize a difference in 4K unless you are a home theater nut.
Wow. You guys don't even let stuff get old, before you start replacing. I should hang out at your trash heap. Better than Best Buy.?
Yes Neal,
Dish offers 4K service
4K TV Programming and Channels | Ultra HD DISH 4K
