On Demand HW Heater question
RVThereYet
Ft Worth
Alliance
Avenue32RLS
Fifth Wheel
First ONDemand water heater I've owned/used.
I understand that it takes time to get the water to the shower. I turn the hot water on, it gets hot, turn it down about half way and turn cold water on about half way. Make minor adjustments to get the temp right and shower. Minutes later, the water turns cold. Have to go through the whole routine again to get the hot water back. Water is plenty hot in bath sink and kitchen sink and doesn't seem to "fade out" like it does in shower.
Has anyone found the trick to using this OnDemand water heater?
I like it. Not Boon Docking friendly but works great with FHU's.
Our water heater has a digital control to set the desired temperature.In the summer we find 106-109 degrees is plenty.We set our temp then turn all hot water on, occasionally adding just a little bit of cold if it gets to hot.Seems to me the newer water heaters have very sensitive pressure flow control switch’s which I believe are for scalding safety as my 6 year old tankless in my older RV works much better at regulating temps.I totally agree these water heaters are not best for boon docking.
Pure genius!! Never thought about just setting the temp that is comfortable for you. Can be set individually and maxed out for doing dishes!!
Thanks, I will for sure give that a try!! I will try the 106 to start and go from there!!
LOL your welcome, but I can't take credit for that.I purchased a tankless for my 2007 Sandpiper RV 8 or 9 years ago which is on a Permanent year round site, so water and sewer was no issue as the RV is connected to both.The counter guy gets the credit.When i pick up the water heater he said " you do know how to connect and use this right? "my response was yeah I think so.The digital temperature display and controller was an optional extra add on which he notice was not on my bill with the water heater and he asked if i had one.I said no and he said "well you can't get the efficiency from this water heater without the temperature controller because the idea is to only heat the water you need to ( here's the big one ) the temperature you need....LOL it was a A HA moment for me.So now my wife and I have our shower number we like which changes with the seasons, winter time I like it a little hotter then summer, my wife likes its hot all the time, and for the kitchen dishes, i think we just leave it where ever the last person who showered set it, just retired n lazy. We run our Renni tankless at home the same way, I even installed a remote controller in the bathroom for convenience .
We too are dealing with a tankless water heater have always had the conventional style. First impressions I don't like it. Wastes a lot of water. One of the other posters is spot on. Find your indoor thermostat.{ Ours was hidden under the sink and has now been moved to the wall}. Set it around 106 degrees for a shower and only turn on your hot water. If you turn on cold it will not have enough flow and will shut off. You also have to leave it on while showering. If you shut it off the heater shuts off. So you end up with some hot then very cold then back to hot, like I said a real water waster for an RV.
One thing we have found. We live in central Tx and when the temps were in the high 90s I would set the water temp to 102 for shower. Immediately the temp would go up to 110 or higher. On a trip to red river nm day time temps in the low 70s. Set the water to 102 for shower temp would drop to low 90s. Ambient temp seems to make a difference on temp from shower head, also whether the water supply hose is in the sun or not. We have owned this rv going on 3 months now so thinking we may have shower temp figured out, now working on 12 volt fridge
