Towing full size truck
Jeff & Kathy
Galveston Tx
Thor
Palazzo
2020 Jeep Grand Cherokee
Locking for suggestions for the best way to tow our full size GMC truck. Thanks
The first thing you need to find out is whether your specific year/model truck is actually towable with all four wheels on the ground. Some are not due to transmission/driveline configurations. I would check with your GMC dealer on this before proceeding.
Sorry Jeff or Kathy it's impossible to help with the little tiny amount of information given. Please completely describe the vehicle being towed and what you're going to tow it with.
Thanks for responding, we have a 2020 GMC Sierra 1500 2WD we are wanting to tow with our future Motorhome ( still in decision ) mode. Probably at a 36-38 ft gas coach.
Typically a truck must be 4WD to be flat towed, so the transfer case can be set to neutral. If you have a 2WD drive truck you'll probably be out of luck.
If you choose to dolly tow or other options, you'll want to look carefully at the curb weight of your truck, it would appear to be about 5000lbs (2020 Sierra Denali 1500: Pickup Truck - GMC), or 500lbs more if you have the 6.2L, then you'd need to add the weight of the dolly. Make sure you look for MH's that have at least a 10,000lb hitch, even though 5000lbs is close, best to have overhead for this. Furthermore, you also need to look at MH's that have enough "capacity" to handle the weight of your tow vehicle. This is typically shown in the specs as CCC , Combined Carrying Capacity, or Newmar calls it the " APP. NCC". This is the difference between the max weight of the MH (GVWR) and the unloaded weight.
Bottom line, you will struggle with a gas MH with the weight of your truck, while still allowing for belongings, food and drink and people and pets you want to travel with. You might want to consider a Diesel pusher in your budget and trading in your truck for something you can tow. In a perfect world!
@VTPete gave you some very good information. After a little quick research online, it does not appear that your 2020 GMC Sierra 1500 2WD pickup is suitable for "flat" towing. Using a dolly will add 1,000-1,500 pounds to the overall weight being towed, putting you well over what smaller, gas-powered motorhomes can safely tow.
Unfortunately, you are trying to put incompatible components together here. If you plan to move forward with buying a smaller motorhome, you might want to see if you can swap your 2WD GMC for a 4WD version that would be flat towable. Or, trade it for something a bit smaller like the Chevy Colorado. The other option is to purchase a larger, more powerful motorhome capable of towing 10,000 pounds or so. That would allow you to safely use a dolly, though the storage issues mentioned by @VTPete would still exist.
The best solution, in my estimation, would be to consider what motorhome would really suit your needs best and then trading your 2020 GMC Sierra 1500 2WD in on a more suitable vehicle to be towed behind it. While that option might seem to be too much of a hassle, I think it would be less of a hassle than allowing one component (your current truck) to dictate your choice of motorhome.
Some very good points, You might be able to flat tow but it's not going to be easy or practicle really. You will need to disconnect the driveshaft from the rear end or you risk severe damage to the transmission. I don't think (not sure) dolly towing is an option, this is a rear wheel drive truck and dollys are used with front wheel drive vehicles.
You could get a trailer and tow the truck on it.
Looks like Pete and TJ are pointing in the correct direction.
I have not used one, butI have seen them in use. They do work...apparently...but are a bit pricey; $1,200+
True, but a tow dolly is about the same price or more.
Attached are pages from the owner's manual regarding recreational vehicle towing. In summary, the 2WD is not directly flat towable, as built. Disconnecting the driveshaft or all four wheels on a trailer are the first options that come to mind.
Yes, you are correct. IMO, however, neither option is nearly as good as having a tow vehicle that is designed to be towed; nor, as inexpensive in the long run.
I don't know. :) Kind of depends on the cost comparison of the vehicle designed for flat towing and the 2WD vehicle you already have and if the you use the vehicle for other things beside RVing.
