When the water softener goes unused…
Richpatty
Wesley Chapel, NC
Ventana 4310
400hp
2007 CR-V
Random question. I know many of you have a water softener…I have a On-the-Go double and it works well, but with us traveling less, I have wondered if it is bad for it to sit unused (empty or filled with water) and could germs/bacteria build up in there? Or does the salt help prevent that?
At one point I went about 2 years without using it and when I went to take it on a trip, I was concerned about it so I called the company and they recommended running Sani System through it, which I did. More recently, to hopefully head off running the Sani System solution, I have been running water through it at least every other week if we are not traveling. This keeps fresh water in it (that has some chlorine from our tap water) to hopefully keep it clean.
The question (finally) is, what do you guys do, if anything, to keep your water softener fresh between trips?
I do like you do and run water through it every couple of weeks and so far I seems to do the trick. I will be curious to hear what other are are doing.
I have the Pro Aqua and always try to back flush it when we return from a trip.
Until the next trip I do just like you guys and run some water through it every couple of weeks.
Before winter storage back flush and then completely empty the tank and store it in my basement.
Next season I use the sani system, regen, and off we go.
I guess we won’t find out what others do…
I'm in the same boat @Richpatty - maybe email the vendor to see what they say? I wonder if a little chlorine is worthwhile and then regen it?
I think the key is to make sure the unit is completely sealed up when not being used. Water sits in the pipes in the rv and at your home when you travel without a concern. Why should the softener tank be any different? Running a thorough rinse before use should be sufficient IMHO.
You pickle the water maker on your boat if you are not going to use it for a while. Why would a softener be any different?
My understanding is bacteria, and anything else that might grow, needs to be in the water to be a problem.
Nothing I can think of will purify better than an Ozone generator.
I kinda fall in this category. I back flush and sanitize it annually, otherwise it’s in use or sealed up.
Thanks. So do you leave it full of water and not drain it? I figure air would be worse than having of fill of water…?
That’s my thought process and what I do. Besides, it’s virtually impossible to drain all the water out of the tank.
I follow On the Go instructions.
Storage Instructions:
Before placing the unit in storage.
Step 1: Perform a back-flush.
Step 2: Perform the regeneration process.
Step 3: Drain water from unit (do not dump the resin out).
Step 4: Unit is ready for storage.
Post Storage Instructions:
After extended periods of non-use, sanitize the unit by following the instructions below:
Step 1: Perform a back flush.
Step 2: Completely drain all the water from the tank.
Step 3: Remove top cap and mix 1/4 packet of Sani-System with a gallon of water for the Standard Model,1/2 packet of Sani-System with 2 gallons of water for the Double Standard Softener, or 1 full packet of Sani-System with 4 gallons of water for the Park Model Water Softener.
Step 4: Connect the water source to the inlet of the softener, pour the solution into the tank, put the top cap back on, and let it sit for a maximum of 60 seconds. Step 5: Turn the water on full stream for 10 minutes and flush the Sani-System out.
Wow Clodhopper, I commend you if you follow those instructions consistently. Good job for sure.
Sadly, there are also so many other areas of sanitation that most people don’t pay attention to. I hate to even start with watching people hook/unhook their water & sewer systems (and their soft water tank). And handwashing/sanitizing are a disaster with most people never even thinking about it while sticking their hand in a bag of potato chips.
I’m not trying to high jack the thread, I’m just saying that I’m happy with my thoughts on care of the soft water tank and think the mfg directions are a bit lawyer driven, especially with all the other areas where contamination is much more possible. 😁
You lost me at "bit lawyer-driven" since I'm more engineer-driven. We've been traveling since late March, and I have regenerated my softener as needed, backflushed once, and sanitized the fresh water system twice because we've been on well water several times.
