AC low on Freon
bro61021
Palm Coast Florida
Keystone
Springdale
33FT
None
None
My AC unit still cools but stuggles when in the direct sun above 90 degrees. It runs continuously. We had the unit seviced but no change. The tech said we are low on freon and would need to replace the roof unit as you cant add freon to RV AC's. Is there a way to splice the lines and add a valve to add freon.
How does he know it's low on freon? Meantime, if you're trying to cool a 33' travel trailer with one rooftop ac in direct sun @ 90+° it's not likely going to shut down.
Usually when they leak Freon, the inside coils (evaporator) will ice up.
Perhaps the fan and/or ducts need cleaning.
My 2017 34 ft Class A would keep the interior at 74 degrees in Florida, in July, in full sun, with one 15k BTU a/c.
It’s not ideal, but one should work fine.
