What's wrong with this picture...?
tcdavidson
Santee, CA
Tiffin
Allegro RED 34QFA
Cummins
Jeep Wrangler
First time I have seen gate valves pointing up...?! That can't be right...?
How does it drain after you close the valves...?
???? With valves closed, it does not, nor should it, drain.
I strongly suspect that that clear tube swivels downward for the actual draining.
Newbie to the Class A world, yes indeed it swivels. I assume the orings need a periodic application of lube?
