Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
The best way to level any motorhome is follow the procedures outlined in the owners manual.The best way to level a Newmar motor home equipped with air suspension, is to:
Prove me wrong.
- Pull into your site,
- Level your motor home,
- Extend the slides.
Quick question, Dennis. What if the front (or rear) of the coach is 10* lower than the apposing end?In our manual, and what they put out at the Academy class, was slides operated at ride height.
Jacks after that when parking and jacks up, ride height, then slides in before leaving.
Fair enough, but that’s kind of my point. The owner’s manual now says slides first unless the site isn’t level. That leaves a big gray area. How does the average RV’er know when the site crosses from ‘level enough for slides first’ into ‘too uneven, better level first’? Without instrumentation, that’s just guesswork.The best way to level any motorhome is follow the procedures outlined in the owners manual.
I see your point. I'd default to level first in that case.Fair enough, but that’s kind of my point. The owner’s manual now says slides first unless the site isn’t level. That leaves a big gray area. How does the average RV’er know when the site crosses from ‘level enough for slides first’ into ‘too uneven, better level first’? Without instrumentation, that’s just guesswork.
So yes, I agree the manual is the guide, but it also leaves the average owner holding the bag on judgment calls it doesn’t define.
I think that’s the safest play too. Level first takes the guesswork out of it, and I’d rather be consistent than gamble on whether the site is ‘flat enough.’I see your point. I'd default to level first in that case.
Great explanation @Neal, and I think you’re right about the risk of chassis twist, especially with a full-wall slide. That’s clearly part of the reason Newmar now leans toward slides-first while aired up.The slides first discussion has come up many many times and I'm not the expert, there may be guidance specific to your coach, but here is my personal opinion and belief:
You typically want the slides going in/out when NOT on jacks. Some will say "at ride height" which means on bags and not jacks. Jacks can cause the chassis frame to twist and with the full wall slide (FWS) this could be problematic. Newmar's guidance is to check the FWS reveal (gap) to make sure it's uniform, i.e. no evidence something is out of whack, I mean, twisted.
I have air leveling like you. I have no problems running my slides air leveled as I'm not on jacks. As long as I'm on bags and not on jacks, my opinion is the slides are safe to run. Your slide is hydraulic, mine is electric. I think yours travels in a cage on a chain link contraption, mine runs on rails. Some hydraulic slides have taken out ceramic floor tiles. So you need to be extremely cautious of this.
Again, just my $.02 but I caution against running slides with jacks deployed, sir!
How hard would it be to glue a level to the side of your RV like I did?Fair enough, but that’s kind of my point. The owner’s manual now says slides first unless the site isn’t level. That leaves a big gray area. How does the average RV’er know when the site crosses from ‘level enough for slides first’ into ‘too uneven, better level first’? Without instrumentation, that’s just guesswork.
