I have the same problem in my 2004 Fleetwood Bounder 39z. I have had it looked at 2 times. The chaise is a Freightliner. This was a problem with models 1999 through 2005. I was told there were no new VDC/VCM s to be had. Miraculously they have found 3 new ones in their Memohis warehouse. They aren’t cheap. Also could be your gauges. I also order a new engine temperature gauge just so they can test the gauges to see if they are out. I also have newer gauge wire to test the gauges myself. I hope the new VDC/VCM will fix the problem.Just bought a 2005 Fleetwood Southwind. Chevy chases. The instrument cluster is a mess. RPM inop. TEMP - inop FUEL inop. erratic I can read live OBD data on my phone.
Please let me know if you get this issue resolved. Thank you.I have the same problem in my 2004 Fleetwood Bounder 39z. I have had it looked at 2 times. The chaise is a Freightliner. This was a problem with models 1999 through 2005. I was told there were no new VDC/VCM s to be had. Miraculously they have found 3 new ones in their Memohis warehouse. They aren’t cheap. Also could be your gauges. I also order a new engine temperature gauge just so they can test the gauges to see if they are out. I also have newer gauge wire to test the gauges myself. I hope the new VDC/VCM will fix the problem.
Please let me know where to get the instrument cluster if this is how you fixed the problem.I have the same problem in my 2004 Fleetwood Bounder 39z. I have had it looked at 2 times. The chaise is a Freightliner. This was a problem with models 1999 through 2005. I was told there were no new VDC/VCM s to be had. Miraculously they have found 3 new ones in their Memohis warehouse. They aren’t cheap. Also could be your gauges. I also order a new engine temperature gauge just so they can test the gauges to see if they are out. I also have newer gauge wire to test the gauges myself. I hope the new VDC/VCM will fix the problem.
I have searched for new. Do you know of a good supplier ?Don't waste money sending in it for repairs, buy a new one or even one that has been refurbished..
StevePlease let me know where to get the instrument cluster if this is how you fixed the problem.
Thank you Steve Goebel
2707 Sierra Vista Rd.
Grand Junction, Colorado 81503
9708126444
