Dead 110v plug for Girard Awning
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
I went to the Oklahoma State football on Friday. I tried to deploy the Girard awnings. No response. The controller showed to be transmitting, but the awnings didn't move. I got home a bit ago and checked the controllers in the basement. They were not lit up. I ran a cord from a good source and plugged the awnings in. They worked. There are no tripped breakers. I checked the two GFCI plugs in the midship bath. They appear to be good. Is there another GFCI I don't know about?
Each model has numerous GFCI hidden -
On ours - we have GFCI
2 in the electrical cabinet in the middle bathroom
1 in the sink cabinet in the middle bathroom (On the outside wall)
1 in the kitchen above the sink (mounted on the bottom of the dish cabinet)
Thanks Steve. I found the one under the kitchen cabinet, It apparently protects all the plugs on the off driver side wall plugs. I finally found the third one in the mid bathroom. It is in the medicine cabinet. When I reset it the central vac came on. The door on the vac had been bumped open at some point and time and I guess it caused the GFCI to trip. That plug protects all of the plugs in the basement, bedroom and back bathroom (but not the washer and dryer). I am thinking there has to be one more to protect the driver side wall plugs. I guess I will find it when it rears its ugly little head.
I believe I also have a GFCI in the rear bathroom in the cabinet under the sink.
I have 2 in the mid bathroom — one in medicine cabinet and one in skinny cabinets below.
I have stood on my head in both bathrooms and haven't found an additional plug. The two in the electrical cabinet protect the floor heat circuits in the main panel. The five circuits in the sub panel are, the frig, the microwave, driver side slide out, passenger side slide out, and the bedroom, bathroom and basement circuit. That last one is the one I haven't tracked down yet. All of the plugs in those areas have the stickers that say they are GFCI protected. I haven't tracked the "mothership" for that circuit down yet.
You may have one in the pegboard bay.
