Recent Upgrade
John&Andrea
Dallas Georgia
Coachmen
Concord 300ts
E450
7.3 Godzilla
2019 Ford Ranger
I just installed a Safe-t-plus steering stabilizer on our Concord. Two test drives and made some adjustments.
It seems to be great on the test drives, I’m ready for a trip to put it to the real test.
A big difference from the stock stabilizer.
I installed one on my F53, well worth the money and effort. I was maniacal about getting it dialed in but I think it's damn near perfect.
Did you upgrade the sway bars? I may do that as well.
No I haven't but have looked into it and it certainly is a DIY, however, they just seem to be a little thicker than the originals with no real modification to the original design. I'm not sure the ROI will be worth it.
The first thing I did was the Cheap Handling Fix where I dropped the front sway bar down to the lower setting and immediately felt the difference when stepping into the coach, it didn't dip as much when I stepped up on it.
I have the steering upgrades and notice as well that if I inflate the rear airbags to the maximum, leveraging pressure onto the front tires there's a marked improvement in front end handling.
I have wondered the same thing. I will go with this for now, maybe look at increasing the air bags as suggested. I run 80 in the AB most of the time. I think 100 is max.
When you say dial it in....is that an adjustable pressure damper?
By getting it dialed in I'm referring to the procedure outlined in the installation guide on how to ensure the coach tracks as straight as possible w/o pulling left or right as a result of how the stabilizer is oriented. Basically, if it pulls one way or the other you loosen the bolts holding it tight and make slight corrections, tighten back up and go for another ride to test. I ended up doing this numerous times to get it as perfect as I could.
on our class c we had installed Roadmaster sway bars both front and rear. much thicker than the ford chassis originals and made a significant difference. very little lean side to side. do it ,you will be pleased
