John&Andrea
- Jan 28, 2021
- Dallas Georgia
- Coachmen
- Concord 300ts
- E450
- 7.3 Godzilla
- 2019 Ford Ranger
Did you upgrade the sway bars? I may do that as well.I installed one on my F53, well worth the money and effort. I was maniacal about getting it dialed in but I think it's damn near perfect.
I have wondered the same thing. I will go with this for now, maybe look at increasing the air bags as suggested. I run 80 in the AB most of the time. I think 100 is max.No I haven't but have looked into it and it certainly is a DIY, however, they just seem to be a little thicker than the originals with no real modification to the original design. I'm not sure the ROI will be worth it.
The first thing I did was the Cheap Handling Fix where I dropped the front sway bar down to the lower setting and immediately felt the difference when stepping into the coach, it didn't dip as much when I stepped up on it.
on our class c we had installed Roadmaster sway bars both front and rear. much thicker than the ford chassis originals and made a significant difference. very little lean side to side. do it ,you will be pleasedNo I haven't but have looked into it and it certainly is a DIY, however, they just seem to be a little thicker than the originals with no real modification to the original design. I'm not sure the ROI will be worth it.
