Question All dash warning lights remain on after repair of ABS sensor.
Poozle
On a recent trip I ran over a ladder that had fallen out of a truck. The ladder cut the wire to the passenger side rear. Mechanic says the senser was replaced with a factory replacement. He does not know what to do, suggest taking to a Mercedes dealer. First problem is there is no dealer that will work on a Sprinter MH in my area. Second problem is that my daughter also has a Sprinter chassis MH and it also has the dash light issue after a recent replacement of a chassis fuse.
Any ideas?
First check that the ABS fuse, under the drivers seat or in the footwell, is good. A blown fuse will keep the light on. Be advised meantime, AI says a malfunctioning ABS on a heavy sprinter chassis is a significant safety risk.
From experience I have found the ABS sensors are "sensitive" It's possible the "ladder incident" affected another sensor. I suggest raising up the front, removing the sensor heads, clean with a cloth, replace and push in all the way. Do this on all four. You may have to drive the MH a few miles for a reset, but if it's your sensors, this should fix it. Good luck, Blessings
Any ideas?
We have been in business for 40+ years. We specialize in Sprinter repairs, sales, suspension upgrades. We also have a large selection of new parts. We get you back on the road usually the same day unless its a major job, however even then, we get you in and out fast as we can. We all know life is short!
AUTO CARE CENTER INC - Car Dealer in Fort Pierce, FL
772-461-2114
772-461-2114
Any ideas?
772-461-2114
Any ideas?
772-461-2114
