Bit of a Newmar rant.
lostinfla
Professional nobody
Dutch Star
2026 Willys 2 door XR
I decided to do a little touch up on the bin areas of the coach, so not knowing where to purchase a small bit of matching color, I turned to Newmar parts dept. The gentleman I talked to said they do sell touch up kits, just shy of 100.00. I asked if the paint was base coat (flat finish) or single stage (gloss finish) and he said it was single stage, so I ordered one. The kit of 4 - 1 oz bottles were delivered about 2 weeks later. First nice day today, so I decided to go out and take care of one side of the coach. I carefully applied a coat of black to one small scratch, and stood back to admire my work. As the paint dried it turned flat, :mad:and now looks worse than the original damage. I took a sample of each color and let them dry with the same results. Called Newmar parts and they said "yeah, I guess that's the way they ship it. You can go to an automotive store and buy an aerosol of clear.... " at that point, I stopped listening. Lesson learned.
I would ask for the $100 back...as they did not sell you what they said. Did the color at least match?
I'm pretty sure that's a dry well. The color does match, just flat. I'm going to try a little light compound on them.
If the color matches but the sheen is wrong, I'd paint a good size square on cardboard then after it dries an auto paint supplier may be able to match and mix up a bit of it. Problem might however be finding an old style auto paint shop.
While employed at a huge collision shop, part of my duties when I started there was mixing automotive paint with various alternate shades. The paint on our coach was an upgrade from the Essex line and has purple, green and silver/gold fleck in the black, so not sure if they could even replicate.
That's what I should have done. 🙄 Tomorrow I'm going out and buying 100.00 worth of black nail polish. 😁
I forgot to mention, she buys it at Dollar General, $1.45 a bottle
I have been able to take a base coat paint, after wet sanding and polishing, you could not tell that there was not a clear coat. I have never attempted it with black but I have with custom mixes. Black is a tough color.
Thanks!
I did find the paint recipe for my coach on Newpar under coach specific. If you had that and went to the right place they could mix you some up. Problem is you would probably have to buy a quart and it won't be cheap.
And it is very likely to be a Base/Clear product. they can mix your base but you will then need clear , reducer and hardener and the ability/tools to spray it on.
My coach was "special paint colors".....three of the four anyway.
Got touch up color kit when I picked up my coach at Newmar.
Used the maroon & the black....then covered with "clear nail polish"
I took a match from a matchbook, and used the "feathered" end where it tore out. An old body shop man showed me how to do it. Works wonders when applying, and dries smooth.
A slight touch the same way with "clear" polish, and if you don't know where it is, you cannot tell it was ever touched up!!
