Insiginia TV on 12 volt
Only with the genny running, or activating 12v inverter if you have one. Obviously, plugged into shore power will work also.
Thanks!! I will look into what specs. the invertor should have for this use.
Now would be a good time to calculate all your inverter/12v needs and match a dedicated battery for it.
We do not even know whether the OP has an inverter.
BTW, OP, there are portable inverters that plug into your 12v outlet, however, only intended for light duty use.
I see no reason modern flat screen TVs would not work; keeping the laws in mind, of course!
He's looking into one.
Good Idea!!! Will do.
Thanks!! That looks like the way to go.
