Boondocking w/propane
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
If I am Boondocking and using my propane furnace will it cause any damage if my batteries die overnight? No solar, trailer not plugged into the truck.
It will damage the batteries eventually. Even lithium should not be drained 100% repeatedly. My 1 - 100ah lithium ran my furnace and residential fridge all night and only got down to 65%. Worth it if you boondock.
First time in 4 years we have needed furnace overnight and Boondocking. Just regular batteries.
Hmmm Leave the furnace turned down very low, put an extra blanket on and "snuggle"! :) The blower takes up quite a bit of juice I believe.
The only issue I can think of is that RVs built in the last 20+ years apparently have solenoid valves in the propane line to the fridge that will close if your battery goes dead.
Then again, if it's cold enough to need the furnace, what are the odds of your food going bad in a few hours at night where you're not opening the fridge?
The valves open when voltage is applied to allow propane to flow. Lack of it will also prevent the board from working. Somewhere around 10.5 to 11 volts.....depends on the unit.
As was stated above draining a lead acid battery can result in warped plates. It's just a matter of time. They can warp on the very first abuse,or you can get lucky.
Lifepo4 batteries have a BMS that disconnects the cells at typically 20 to 30 percent charge. That of course depends on if the BMS is working properly.
Thanks to everyone for the advice, thoughts and tips.
Everything went as hoped last night. I woke up around 3:00 and turned on the furnace.
We don’t have a propane fridge 12 volt only. Propane for cooking and furnace only.
When parking and on shore power or plugged into the truck the Lippert level system showed 13.7 v. On the electrical board the Battery has lights and can show “ L F G C”. I checked it at bout 7:30. It showed a strong “G”. After getting ready to close up and leave the Lippert read 12.2 v. Drove all day and everything is back to normal now.
