YouTube I Tested 9 RV Water Pumps! Here's The Best One! (Surprising Results)
Watched it last night....I will be purchasing one. Have never liked the ones we installed. pentair, flojet, and other ones customers bought.
Nice video. Straight and to the point. Well put together.
I wanted more volume and pressure. With my circulation loop on the hot water, I can now take a longer shower. My new Vevor pump also gives me extra pressure. Higher pressure helps with the Onboard Reverse Osmosis system. I only use Reverse Osmosis for DRINKING WATER. As for reliability, time will tell.
I did have to run a dedicated 30-amp line from House Batteries to the pump. The original “Barth factory pump switch” serves to activate the relay.
HMMMMM. The only way a pump can result in a longer shower with available hot water is if its flow rate is reduced from the previous setup - assuming no other system changes from the previous pump.
