YouTube I Tested 9 RV Water Pumps! Here's The Best One! (Surprising Results)
  • Thread starter Thread starter Neal
  • Start date Start date
  • Featured
Administrator
Cummins 400 HP
Watched it last night....I will be purchasing one. Have never liked the ones we installed. pentair, flojet, and other ones customers bought.
Nice video. Straight and to the point. Well put together.
I wanted more volume and pressure. With my circulation loop on the hot water, I can now take a longer shower. My new Vevor pump also gives me extra pressure. Higher pressure helps with the Onboard Reverse Osmosis system. I only use Reverse Osmosis for DRINKING WATER. As for reliability, time will tell.
I did have to run a dedicated 30-amp line from House Batteries to the pump. The original “Barth factory pump switch” serves to activate the relay.
Put one in and replaced it 2 months later. Have removed several.
HMMMMM. The only way a pump can result in a longer shower with available hot water is if its flow rate is reduced from the previous setup - assuming no other system changes from the previous pump.
Remember I have a circulation loop.
The Vevor has been working since 9/25. Keep in mind you must NOT starve the Vevor, as it requires 20 amps minimum. My Vevor is powered directly with #10 marine grade wire. I also have dedicated ground to the Vevor.
Vevor also needs more water feed. If you are burning up the Vevor, it may not be getting the required power or water feed. Vevor may occasionally run while hooked to shore water to keep up the water demand.
Time WILL tell.
