Water heater leaking
Corilou
Hello everyone, can someone please help. Where can i find the shutoff valve on my water heater for my 2003 Springdale travel trailer. My water heater is leaking and I want to bypass the water going into the water heater. Everything on here is in its original condition. After changing the water heater anode the pressure valve won’t stop draining water and water is coming from underneath the carriage. Unfortunately i can’t hire my RV tech person right now,, so I’m just trying to help myself for the time being until I can. Any help or suggestions would be greatly appreciated!! Thank you
There may not be a shutoff valve. It depends. If the pressure valve is leaking you can try burping it. Turn off the water pressure to the camper and flip the valve open with the little handle on the pressure valve. You rotate it upward or downward to open it. Sometimes they get dirt in them or just need to be reseated.
Also, there is supposed to be an air pocket in the tank. With the pressure off, open the pressure relief valve and let it drain until it stops. Then flip it a few times and turn the water back on. CAUTION....if the water is hot that is what will come out!
Welcome aboard. Can you find access to the back of your water heater? If you are lucky it might be near a cupboard and visible from there. If not, you may find an access panel that will need to be removed. Once you have access to the back there might be a bypass system that you can use. You can check out You Tube for instructions on how the bypass works. You may need to replace the pressure relief valve. Instructions on how to do that too should be on You Tube.
Good luck
We had a T&P valve start dripping once after winterizing our RV. I tried several things and finally found that we had a buildup of calcium/lime that was preventing a good seal. I opened the valve (with no pressure) and sprayed LOTS of CLR or LimeAway (not sure which one) into the valve and let it soak a couple of hours...did it again...and again. Ultimately the drip stopped and all was good.
T&P valves have two functions. Try shutting off the burner first. If it quits leaking, have the temperature reset.
There is a thermostat on the face of the water heater that controls temp, the one labeled ECO is the overtemp limit and shuts it off at about 180*F. They are little discs that are held in place in contact with the shell by springs. Annoying little things they are.
@TheLooks Is that what you'd use to also lower the temp of the water in the heater? Mine is way too hot.
