Slide goes out hard
John Burke
2022 Jayco Eagle HT CKBS. Three slides. The living room slide, curbside, has an issue when going out. If I push the extend button it will make the ratcheting sound like they do when they are pulled in and hit the end of their travel and not move out. If I tap the extend button with VERY short pushes after two or three try's it will go out like it should. I thought the slide stop needed to be adjusted. Took it to my dealer, they experienced the same issue. They called Lippert, Lippert had them check the voltage to the motor. Was 13.4, resting voltage for my batteries, dropped to 12.6 when the switch was activated then went up some after the slide started to move. Sounds normal to me, more power draw when starting an electric motor than when running. I have 2 200 amp hour Lithium batteries installed. Lippert's answer was the problem is the lithium battery's, they cannot handle the starting power. Need to have lead acid instead. The batteries have been installed for two years, and the problem started 6 months ago. My thought is if the batteries are causing the problem, it should have shown up a long time ago. I have lithium in my Jayco, my pop-up and my cabin. No issues. My understanding, from watching the volt meters and battery manufacturers info is that lithium will hold the voltage steady until almost dead. Like a straight-line discharge. Lead acid will do a gradual drop, like if you are looking at a graph and the line runs from full down at an angle to dead. Of the other two slides, one is a cable drive and the bedroom one is the same Lippert style, no problem with it. My experience level is not just driveway experience. I spent 44 years as a mechanic working on anything from weed eaters to trackhoes, and most everything in between. My thought is that Lippert does not have a clue and is looking for an excuse to pass off the problem to me. Does anybody have any thoughts as to what could cause this problem?
Did that, cleaned it up and used a dry graphite. My thought is that the drive motor is getting weak. Needs a little extra to get it going and then it is fine.
It is not the motor, the motor has a rubber clutch between it and the actual rod that spins to move the slide. They can get weak but I have seen relatively new ones do it and when replaced with a new motor and clutch it still did it. It took us a whole day to adjust the slide box so that it was not jamming on something unseen. It pushed one of the crappy little stop cans right thru the hole in the frame on the first motor...so the clutch was working! I think the adjustment that finally made it work was the vertical ones on the outside of the box. Be very careful adjusting these things.
Thank you
On a previous RV we had one of the gears broke a couple of teeth and it started making a horrid noise when we opened and closed the living room slide. Might check that. We eventually had the fifth wheel in the shop for something else and had that fixed while it was there.
Ok, I lean towards what @TheLooks has said. The gasket, if it flexes will allow you to push in on each side while having someone press the switch. If pressing one side the actuator works seamlessly. That side should be adjusted a little looser. Otherwise adjust the limit switch if it has one.
No limit switch, it just slips on the rubber clutch in both directions. Horrible set up.
