Leprechaun M319 side widows fogging between layers
Edward1954
Looking for information as to how to remedy this problem ? Also is this a manufacture defect that would be covered. My model year is 2017 and it has always been kept in shed and only on trips for 3-4 times at most per year.
Anyone else delt with this issue??
Welcome to RVforums from Ely, Iowa. A couple things. Once you separate the panes the vacuum seal is gone so the performance of the window will be decreased. Also if the fogging is bad enough it can etch the glass and while you will improve the visibility of the window it may not be perfect.
Please post your results with photos. I have a couple windows I am going to remove and attempt to clean as well. They are small side slide windows
The video on the site I provided indicates that there is no vacuum in the double pane windows. The seal provided in the kit helps absorb moisture. Pretty interesting video.
I met the guy “Jeff Bolton” from DYI RV Solutions today. Very nice guy. Hey only lives about 15 minutes from me. Anyway, I got the things I needed from him to do the repair on my windows.
I should be starting tomorrow. I’ll let you know how things go.
Well guys I started work on the window about 11am today. I followed the video pretty close. One step extra is I remove the shades for the window. They were just too close to get anything on the screws. Not a big deal however.
I did have to push on the window frame a good bit to break the seal on the outside of the window. Twila was on a ladder making sure it didn’t fall out.
We got it in my shop on my work table and following the video opened up the frame and got the window out. It does take a little force to open the frame.
Took the widow apart like the video. Takes a little pressure though.
I used an oscillating tool with a puddly knife attachment to cut the seal. It was like cutting through butter. Then cleaned with razor blade followed by acetone.
After cleaning I put the glass back together like the video, however I did not bother with the taping. I just smoothed it with my finger.
I’m letting it cure overnight before installing the glass in the frame.
Thanks for posting, looking forward to the rest.
I completed the repair on the foggy window. Turned out pretty well. No more fog.
Following the video worked well. The only thing I did different was use a small ratchet strap to help me close up the window frame to screw together.
I know in the video he said wait 20 minutes before installing the window into the frame, I waited over night. I was afraid I’d make a mess. I think 2 people would work better even though I did everything by myself except for removal and install.
Watch the full video first. There is one thing out of sequence.
Well done, is the kit for one window? Would you do it again? What was the hardest part? Cost of kit?
I appreciate your taking the time to post your project, I'm facing the same.
The hardest part is getting started really. I watched the video several times and talking to Jeff helped.
After that, separating the window from the frame was a little nerve wrecking, but not bad.
Separating the two window panes was actually pretty easy with the oscillating saw and puddy knife blade was pretty easy. Take your time and get the old silicone off and clean with acetone.
Since I had pretty much every thing, I bought the 10 ft seals for 2 windows and the window sealant for 2 windows. There on his web site for pricing. I got it a little cheaper. “Neighbor Discount”. It was about $180.00 I think.
The seal you buy has “desiccant” embedded in it to draw moisture out.
Thanks Mac!
For future reference where is DYI RV Solutions?
It gives you the address on the about page.
109 Pearl Cir​
Iron City, TN 38463​
He is about 6 miles from my house.
He is a retired electrical engineer.
Was washing the coach today for Memorial weekend trip and realized my awning mount goes right down the middle of my passenger window that I want to fix. Arghh, I may not attempt it now, I'll have to see what it would take to move it out of the way.
