Edward1954
- May 5, 2026
You double pan windows have a leak and moisture is between the panes. I have the same issue. I’m getting ready to order the parts and repair them. Below is a link that I used to learn how to do it.
The video on the site I provided indicates that there is no vacuum in the double pane windows. The seal provided in the kit helps absorb moisture. Pretty interesting video.Welcome to RVforums from Ely, Iowa. A couple things. Once you separate the panes the vacuum seal is gone so the performance of the window will be decreased. Also if the fogging is bad enough it can etch the glass and while you will improve the visibility of the window it may not be perfect.
Please post your results with photos. I have a couple windows I am going to remove and attempt to clean as well. They are small side slide windows
The hardest part is getting started really. I watched the video several times and talking to Jeff helped.Well done, is the kit for one window? Would you do it again? What was the hardest part? Cost of kit?
I appreciate your taking the time to post your project, I'm facing the same.
For future reference where is DYI RV Solutions?I met the guy “Jeff Bolton” from DYI RV Solutions today. Very nice guy. Hey only lives about 15 minutes from me. Anyway, I got the things I needed from him to do the repair on my windows.
I should be starting tomorrow. I’ll let you know how things go.
