mgarasic
- May 14, 2026
- New Wilmington, PA
- Holiday Rambler
- Ambassador
- 38’
- Roadmaster
- Cummins 5.9l
Why would you wax it? I personally paint metal roofs to reduce heat inside My rigs. Also reduce maintenance if you use silicone roof coat that has a very long life.I have an aluminum roof on my HR, looking for a good way to clean it, it was sitting under a tree for quite a while and is still I good shape but has a lot of oxidation. Also, what type of wax is used after the cleaning?
In the past zinc chromate was used for aluminum primer. Today? I have had good results with tropicoat from Henry's. You should be able to find instructions for painting on aluminum on their website.Aluminum requires a special paint. Read the labels. I think Henry's Tropicool would be great.
