MarkMaxPayne
- May 24, 2023
- Lyons, OR
- New Aire 3543
- 36'
- Spartan
- Cummins L9 Diesel
- Fiat 500 Turbo
An inspection of my tow bar and related equipment after my last trip pointed out some serious issues that needed addressing. The issue was hidden out of view up under where the hitch inserts into the hitch receiver. Apparently when I bottomed out my dropdown hitch exiting an RV park, I not only damaged the hitch anti-rattle collar, but I also severely cut into my safety cables. One of the cables were almost cleaved clean through. The good news is, even though integrated into my RoadMaster Nighthawk towbar, which keeps them nicely routed out of the way, replacing the safety cables and the wiring harness was pretty easy. I decided to replace the wiring harness at the same time even though it damaged.
The cables were on back order from RoadMaster for a few months, but a live person (not AI or a boiler plate e-mail) from eTrailer proactively reached out to me each month to not only apprise me of the status of my order, but to recommend alternative workarounds with other cables if I needed to tow my TOAD before they arrived. When I finally received them this weekend it wasn't difficult to remove and replace the old cables as the tow bar has built in channels in them that accommodate the size of the built-in eyelets. Hardest part was connecting the two power wires for the Nighthawk's built-in running lights along the side of each bar. Even that was pretty simple with a soldering iron and some heat shrink as the power cable between the rig and the Toad already has the two wires for powering the running lights already integrated into the cable at the attachment point just before the cable slides into hole the cable runs through the tow bar.
One other thing I learned from the instructions is that the anti-rattle hitch collars can be rotated 90 degrees, allowing for the adjustment knob to be on the side of the hitch vs down below it.
Recommendation? Pull and move safety cables around when visually inspecting them; where they might be damaged could be up against the hitch and hidden from view.
Best,
-Mark
Best,
-Mark
