Problem Awning
tscharf
Hi. I'm new to the forum and was hoping someone could point me in the right direction. We are on the third day of a three month trip in our 2018 Ventana 4037. Last night it rained (no wind) and our Carefree Trav'R DT awning collapsed. The front arm is completely bent down and twisted. Based on recommendations from the cam
pground, Carefree Colorado's website, and Camping World, we called 6 different technicians. Only one got back to us and said he might be able to come take a look in a couple of days.
Any ideas of someone I can contact to get the awning fixed or removed. We are expecting thunderstorms this evening and I really don't want it hanging there. We are in Richmond, IN.
Your best bet at this point is to probably just remove it yourself. Even if someone gets out there in a couple days they're going to have to order parts if not a complete replacement.
How much time do you have where your are currently? I find it hard to believe just rain fall caused that kind of damage.
Just rain. We had a heavy downpour and I guess it couldn't drain properly.
Someone is coming out Thursday. They have a motor arm that matches the model. We'll just extend our stay by a few days.
I have learned, NEVER leave the awning out if going in for the night or leaving the site. Bad things happen fast. I would contact your insurance company and see if it's covered.
i've seen that happen when it doesn't drain properly
Something I learned is, if I'm not outside with under the awning, bring it in. Our RV had wind sensors but they did not retract as fast as the wind blew.
At least you were not driving 60 mph and had one deploy.
Somtimes I wondered if the awnings are worth the headaches.
Wind and the weight of the accumulated rain water on the awning should have activated the automatic retraction. Check the sensor settings during the repair. If it was just rain, the roller tube would have buckled before the arms.
The driving portion is why we unplug ours before traveling.
Only plugged in when we are going to use them.
I’ve read several stories concerning awnings that deployed for no reason. I’ve also noticed that my sensors have a mind of their own so never leave them out if I’m not out with them. I installed these plug switches so I can easily turn the power off anytime the awnings are in, traveling or not.
I did the same I recall @Neal had a post about this
