Silicone Roof Application
Scooterfan
RVF Expert
Central Coast of California
Canyon Star 3205
Workhorse w20
8.1 L Vortec
Based upon some discussion here, I purchased silicone roof treatment for my RV roof. A recent knee injury (and old age) stabs at my confidence to be able to get up there and do a good job re-sealing my roof. So my hope is to get some recommendations from the (few) California guys on this forum for shops that you might recommend to do this job for me using the product I've already spent $400+ for. I will be traveling from the Central Coast (of California) to Chico (CA) the first of June and could leave it anywhere along the way (say US101 to 152 to I5 to 99). Any great shops that you would take your RV to ? Thanks in advance. Blessings
I'm sorry I can't help with shop locations but I'm curious what the silicone roof treatment is.
Do you mean self leveling silicone? Its supposedly good for the life of the RV. If your newmar has a fiberglass roof that is likely what it has along the caps and around the roof accessories etc. It doesnt need to be removed and replaced like that cheap dicor / lap sealant stuff does
Everything I have seen on this site indicates the cheap stuff is what the manufacturers have used.
Main reason is silicone is not paintable.
I looked into it, fiberglass roofs were an extra cost option on Dutch star + higher end models. They were standard with a TPO type roof
No, I have the one piece fiberglass loose fit roof that was famous for coming undone while traveling and destroying itself. It came undone sometime in the past before my ownership and was poorly repaired but holding. I removed the rear cap before coming west last winter and it was sealed with silicon and I used that again. But the Maxxair fans and other penetrations have been sealed with Dicor or other sealants. I used Dicor around the front cap as it was also poorly repaired. I intend to strip off all repairs and completely redo the roof along with removing obsolete antennae's etc.
Yes the sides need to be monitored religiously as they only used proflex on them. The caps and everything else is Hengs self leveling silicone. They should have known better than to use a sealant on the sides that has such a short service life (relatively). Sikaflex 221 would be better, but would be a bear to remove if it ever needed to be redone - catch 22
Yes, I used the Hengs to put the rear cap back on, I like it. I will not worry about doing it again so I will use Sikaflex 221 when I fix it and will Eternabond the edges. It is 22 years old now and probably will not outlast the repair and the Tropicool.
