Ok Lithium gurus
Looking forward to seeing your new dream come true. Congrats and enjoy every minute!
On the SilverLeaf control panel one can set the AGS based on % SOC vs voltage (voltage doesn't work for Lithium you must go by SOC). You are able to specify the battery type in the configuration screens, which then leverages SOC instead. I would assume ATC config screen(s) would allow for similar, no?
Best,
-Mark
The other part of the equation you didn't get answered is longevity of certain battery amp hours. A 13500 btu AC unit draw about 13 amps while running. There is a burst at startup. Based on the running amps, and knowing that there is some losses due to system inefficiencies, you can divide your battery AH by the running amps and multiply by 80 to 90% to get the hours you can run. Figure 100% SOC down to whatever SOC you want to stop pulling from the battery. 930/13=71.5x85%=60.8 hours. This is a rough estimate as it won't run steady and it is hard to calculate the toll the startup draw will take on the battery depending how many times is starts. Plus I didn't take any capacity out for stopping the drain at 10 or 20% SOC.
And you didn't take into account the added amp draw to get the proper wattage at a lower voltage as the battery level drops.
Lithium does not drop like LA. It maintains voltage far into the discharge cycle then crashes. But I am sure there is an effect.
Yes, and it makes the calculation more difficult to pin down. So I generalize. For people that can't get into the weeds easily.
They install their own AGS and that replaces the one that came with your coach. Small item, not a big deal. Just like my Magnum stuff went away for their product. All controlled from your phone, browser, etc. if you get the Victron setup. I can start and stop my GEN remotely such as I do to exercise my AC's in storage (I can control my HVAC from my phone too using the Smart Thermostat). Far more modern and advanced than anything you're getting out of Newmar IMHO. Here is a screenshot of my web interface for Victron Remote Management (VRM) where I can control inverters, GEN, etc.
I got an answer about integrating a lithium install into the atc panel on a 2026. If I do a lithionics setup, its easy and can be added very simply. If I do another set up, its possible to add it but not guaranteed.
And you can’t disregard the Alternator. Depending on how it is configured…it may help a little (LI-BIM) or more (parallel DC-DC chargers). And like Neal mentioned SOLAR. Batteries get you thru the night….but only if you arrive your destination charged. If you are sitting for days..,then the alternator part is out of the equation.
Chasing the 70 degree latitude helps too.
In my opinion and guess, Lithionics will be the most expensive LiFePO4 option you could choose. Personally I would not do it. I fully trust Brian (owner) of SES Indiana there in Nappanee and that's who I would develop a plan with and get any questions answered. Not for now obviously and most importantly, please share with us that FPU/CPU dream you're living this week. So excited for you!
