Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
And you didn't take into account the added amp draw to get the proper wattage at a lower voltage as the battery level drops.The other part of the equation you didn't get answered is longevity of certain battery amp hours. A 13500 btu AC unit draw about 13 amps while running. There is a burst at startup. Based on the running amps, and knowing that there is some losses due to system inefficiencies, you can divide your battery AH by the running amps and multiply by 80 to 90% to get the hours you can run. Figure 100% SOC down to whatever SOC you want to stop pulling from the battery. 930/13=71.5x85%=60.8 hours. This is a rough estimate as it won't run steady and it is hard to calculate the toll the startup draw will take on the battery depending how many times is starts. Plus I didn't take any capacity out for stopping the drain at 10 or 20% SOC.
Lithium does not drop like LA. It maintains voltage far into the discharge cycle then crashes. But I am sure there is an effect.And you didn't take into account the added amp draw to get the proper wattage at a lower voltage as the battery level drops.
Under load there is a drop, but not linear like lead.Lithium does not drop like LA. It maintains voltage far into the discharge cycle then crashes. But I am sure there is an effect.
I got an answer about integrating a lithium install into the atc panel on a 2026. If I do a lithionics setup, its easy and can be added very simply. If I do another set up, its possible to add it but not guaranteed.They install their own AGS and that replaces the one that came with your coach. Small item, not a big deal. Just like my Magnum stuff went away for their product. All controlled from your phone, browser, etc. if you get the Victron setup. I can start and stop my GEN remotely such as I do to exercise my AC's in storage (I can control my HVAC from my phone too using the Smart Thermostat). Far more modern and advanced than anything you're getting out of Newmar IMHO. Here is a screenshot of my web interface for Victron Remote Management (VRM) where I can control inverters, GEN, etc.
In my opinion and guess, Lithionics will be the most expensive LiFePO4 option you could choose. Personally I would not do it. I fully trust Brian (owner) of SES Indiana there in Nappanee and that's who I would develop a plan with and get any questions answered. Not for now obviously and most importantly, please share with us that FPU/CPU dream you're living this week. So excited for you!I got an answer about integrating a lithium install into the atc panel on a 2026. If I do a lithionics setup, its easy and can be added very simply. If I do another set up, its possible to add it but not guaranteed.
Not sure I get what you're saying. Are you saying you don't boon dock, when you say solar is not needed?I talked to a guy at Rock Springs rally about lithium battery install.For about $4500 you could get 3 lithium batteries that the 1 AC could run 6 hours continuos with 2 batteries, 3 would run longer. Not really a need for solar.
No one was trying to be exact. But if you want to play that way you left out the efficiency loss of the inverter and equipment.Calaculations on run time are wrong. 13 amps of 120 volt =1,560 watts and at 12 volt that is (13) 120 amps into your 960 AH batteries with 20% reservse capacity = 6.4 hours
