Garmin RV795
TheLooks
RVF 1K Club
Harrison, TN
Winnebago
431C Minnie Winnie
31 ft
I picked up one of these as the people that travel a whole bunch seen to have this or the larger version. I spent all day yesterday with AI(its really not that good) learning about file types and converting Gmaps etc. The bottom line was the 795 would not read the files, even when converted and installed into the installed memory. The 64G card I have is a brick it seems, even after getting a long lesson in Fat32 and programs to force the format as my WIn10 won't do more then 32G.....lol. I downloaded at least 5 programs and even paid for one to convert 10 times, to no avail. So, do the members here use Gmaps and print out turn by turn directions and painstakingly enter them into your GPS? Any tips from the guru's of gps travel would be welcome.
I use InRoute for planning (Apple only) that I can export the gpx files from.
Garmin has a drive app that does real time traffic to the gps it is paired with.
I transfer the gpx file through drive and it loads to the gps.
Any planner that can export a gpx file should be able to be loaded to the GPS through the drive app.
InRoute does planning taking into account weight, height, etc.
Struggled with getting the map into Drive. Did not see that Drive would enhance the 795 experience. I was trying to free up my phone for other duties. I don't have Drive on my PC it has Garmin express. This seems useless except to update. Will go back to trying what you mention when I get home from this trip.
Hello. I’ve been using and beta testing the large RV units for years. My current model is the 1095 and is an excellent all around GPS.
I run all trips through RVTRIPWIZARD and use the Garmin as a backup.
That said, I used to use BaseMap but it became a hot mess that was no longer supported.
But, I can tell you the best way for bringing maps into any Garmin product has been the .gpx format. Being universal, pretty much all programs will export and import that format.
BTW, I do all my gps work on a Mac.
Yeah, the drive app does real time traffic etc.
Not sure if you can export a gpx from the maps you are using for planning.
I used a converter to go to gpx and got it into the SD card and it would not read. I moved it to the onboard memory and it would not read. I tried to change it from a trkpt or whatever to a rte....no go.
My 795 will not read the sd card or the gpx files
If the card's not being recognized by the Garmin, my suggestions are:
1. FORMAT the card using the Garmin.
2. Try another card, like a SanDisk 32Gb.
3. Use the Garmin Drive app.
Have you by chance tried using a Mac with "AFT" (android file transfer)? I used to use that program when I was testing. On the Mac, it was used as an intermediary app for communicating to the Garmin.
Yes to file transfer, will have to get another card. I originally formatted the card with the 795
Shoot…kinda outta ammo from this angle, but stay with it if it’s important to you to do. The world of GPS files has been a pain since the very beginning and doesn’t seem to be changing much.
This is why my workflow is so much more simple now. I plan with RVTW.com, then just enter the trip into the GARMIN and away we go. This allows me a way to double-check the routes anyways.
Let us know how you do.
BTW, have you accessed Garmin Tech Support? The folks back there are pretty friendly and always willing to help.
Hello TheLooks,
We use the Garmin RV 780. For simple routes I just use the GPS itself for trip planning. It is a little cumbersome, but it works. From the GPS Apps menu select Trip Planner. You can utilize the entire Garmin database stored on the unit for planning. For more complex trips I use Good Sam's Trip Planner. Save it as a GPX file. I the use a text editor to change the name field of the waypoint from latitude and longitude to my preferred name such as the campground or town and the name field of the trip to what I want. Then I connect the GPS to the laptop and use Garmin's built-in file transfer mode. I use a file explorer on the laptop to navigate the GPS file system to the GPX folder and copy the GPX file there. I disconnect the GPS from the laptop. Power off the GPS then back on. Go to the GPS Apps button, select Trip Planner. My trip shows as an imported trip. Select the trip then select Go. The last method I use is the Garmin Drive app. Within the app on my phone I select where we want to go or stop for the night. I also use the Drive app when we do not have a schedule or we know where we want to end up but everything between is on a whim. Note: the Garmin RV 780 does not support uploading a GPX file from the phone to the GPS. I found that the biggest complaint for the Garmin. I am sure you could use any mapping software that can output a GPX file and upload it with the steps above.
Hope this helps.
