Greenlane Fuel Card
I have a Greenlane card, and I've been told I will get a new 8TK card soon.
Attention: @GreenlaneOfficial Whats up?
I got an email to activate my card. Is this a virtual card or physical card we're supposed to receive? So damn confusing!
Hi Neal, card activation comms are automated comms. We shipped your first card on 6/16 which must have gotten lost in the mail. We shipped a new card out to you last Thursday. It should arrive sometime this week. Sorry for the confusion.
Thank you @GreenlaneOfficial and thanks for the call. I'll let you know when I receive the card.
I agree, I have not used it as it seems too complicated to deal with. Can I just use the card? Do I need to use the app? Do I need to use the card and the app at the same time?
I want to try it but....
At some stations, you use the card, and at others, you will get a code on the app to enter. I know it seems confusing, but after using it a few times, you'll get the hang of it. All I know is this morning I saved 20 cents per gallon, not including the Open Road charges. Greenlane has no transaction fees either.
There are several fuel card options today, so whichever program works for you is the best.
Card received. I definitely didn't misplace that envelope. Hard to miss.
Thanks @GreenlaneOfficial
Step 1) when at the station (and I do this while waiting in line) open the app, from the map it should show you at the station, click on the station and you then have to authorize how much fuel & DEF you want
Step 2) when at the pump, swipe your Greenlane card and then follow the prompts on the pump screen (be sure you select the same choices you did on the app in step 1)
Step 3) pump!
Step 1) when at the station (and I do this while waiting in line) open the app, from the map it should show you at the station, click on the station (and then click buy and click how you want to pay) and you then have to authorize how much fuel (in gallons) & DEF (in gallons)you want
Step 2) when at the pump, swipe your Greenlane card and then follow the prompts on the pump screen (be sure you select the same choices you did on the app in step 1) At some stations you will get a code number on the app which is entered on the pump keypad)
Step 3) pump!
You can choose to use a credit card (2.9 or 2.8%) or cash that you've added to your wallet. For some crazy reason, it takes 3-5 days for the cash to show up in your wallet.
I will forewarn you. If you need to call customer service, be prepared for a long wait time. I've had to call twice, and the wait time has been up to 45 minutes.
@GreenlaneOfficial , is anything being done to improve on this?
Step 3) pump!
Does the pump ask for any type of code like open roads does?
@Neal See my post #55.
So, what if I try to use the truckers pump without any fancy truckers card? Do I have to go inside and pre pay?
I just use the regular pumps since I know what I'm paying and my rig is less than 50'.
Im installing a 60 gallon tank next week so the high flow may be worth all the card juggling.
I also avoid the interstates as much as possible so very few truck stops.
You have to go inside and prepay with a regular card. When you have Greenlane or Open Roads, you know what you are paying as its on the app.
