Haven’t seen this before
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Had a blow-out on the freeway yesterday. I didn’t know it but two drivers passing by were pointing at it. I pulled over and found the attached. Yes I have a TPS system. That’s the surprising part. No alarm and after checking the tire I checked the monitor and it showed the tire at 107 psi. Didn’t notice the listed temp. I use the black rubber pucks on my valve stems. If you look there is a small part of the stem but no sensor. The psi stayed at 107 until
we replaced with spare and started back driving. View attachment 32955View attachment 32956
That's scary! I just bought mine! This is the whole reason I have sensors on both the coach and the towed!! What company manufactured the TPS system.
What system were you using
Using the TST 507 from TSTtruck.com
Been using for 5 years. Always seemed correct. First issue.
That is strange for TST unless it had lost contact with the sensor and just kept reporting the last reading.
That is an odd mode of sensor failure to have. Meanwhile, the use of screw-on-valve-stem pressure monitoring transmitters comes with the undesirable potential for leak down, since the stem Schrader is held open by the add-on. If the sensor connection leaks, it would defeat the purpose..
Did you have a blowout, or was it perhaps a deflated tire that got shredded after it had simply lost pressure, perhaps from a road hazard puncture? Terrible that the sensor masked the problem.
I have hesitated to install the set of four screw-on-valve-stem tpms transmitters that we bought for the OVR. The OVR uses rubber valve stems and the installed sensors would be protruding beyond the flat of the rim face. The mass on the end of the flexible rubber stem is configured to respond to centrifugal force as a "lollipop". Would have to replace the rubber valve stems with bolt-in metal valve stems to mitigate that bending effect.
Wireless camera on the back helps with lane changes, but there are a lot of boxed cctv cameras left over in our shop, unused, from home security system projects. Easy enough to mount two cameras inboard of the OVR's tandem wheel sets to watch both sides and wire to yet another display in the Ram cockpit.
I always hammer checked duals on the HR P30, looking for a tire losing air, done at the beginning of the day, at stops, end of travel day. Still hammer check all the singles on our current rig, looking for any one that sounds or rebounds different..
After seeing your post, we won't be installing or using the cheap chinese tpms set we bought off Amazon for the OVR. Prefer the ability to look at the rolling tires on camera - with all Schraders remaining closed....
I do have rubber valve stems. Have had for 5 years this was a first. I did contact TST about the stems. They said “
Hi Russell,
Thank you for contacting TST.
Yes, the RV cap sensors can be used on metal or rubber valve stems.”
Even though I’ve had no previous issues I am thinking about getting all my tires changed to metal stems just incase.
Yeah, the non flow through they say “can” be used on rubber ones - had metal on both coaches and never had an issue. Did save us twice though in 10 years of traveling.
The new setup with the booster antenna worked well and never dropped monitoring a tire.
