Recommended Tire Pressures 192RBS
miltoch
We just purchased a 2017 Coachmen Freedom Express 192RBS. It has what I believe to be the original tires which I will replace shortly. The sidewall on the tire indicates that the recommended tire pressure is 30psi. I've had many trailers over the years and most if not all have had tire pressures recommended as 50 or 65 psi. Doe 30psi seem to be the correct setting. I have downloaded the Owner's Manual for this trailer but it obviously covers a multitude of trailers of different sizes and weights and is silent with respect to tire sizes or pressures. Thank you for any information.
You sure they are trailer tires? Mine are 65 PSI. 14"
Have you decided on a tire brand yet? I'm going to replace mine before the next long trip. They are 2019 and China made. I've been researching and the Goodyear Endurance seems to be a commonly recommended tire.
The weight rating is what determines PSI. The weight (actual) determines the pressure your tires require. My guess is the tires are C rated tires. Weigh your rig on a scale and look up recommended tire pressure. And yes there are charts that are online for determining tire pressure based on the weight of your vehicle.
Ive been using Goodyear Endurance for a while with no issues. Only flat has been from a valve stem being torn off from debris.
Current trailer has 15" rims with 80psi stated on the tire.
I would just note that my tow vehicle - a 2016 Toyota Tundra weighs 7,000 lbs unloaded and the recommended tire pressures are 33 rear and 30 front. The trailer in question Weighs 6,000 lbs unloaded so in the neighborhood of 7,000 loaded. Same number of wheels on each vehicle - two axles, four wheels - so 30psi would not seem entirely unreasonable. I'm hoping someone with the same trailer can tell me what tires and what tire pressure they are running.
