Towed vehicle battery dead upon arrival at destination
Pat O'Sullivan
This summer we installed a Blue Ox tow package with a Stayinplay braking system. I own a 2007 Newmar Canyon Star 3303 which according to all info I have, it will keep the towed vehicle's battery charged while driving. Our first trip away resulted in a dead car battery when we arrived at the RV Resort which was embarassing and required a boost. This happens when I drive more than 4 hours without checking on the car during the trip. I checked for current at the plug in and got none. I spoke with the installer who said that it might be a blown fuse. Now I have to figure out which is the right fuse. Does anyone know exactly where the correct fuse box is located and which fuse it is?
It can only keep your battery charged if you are running a 12 volt charge line and connecting to your battery via a charge controller.
Your fuse should be located under the hood of your coach. If you have a test light or multi meter, you can check to see if you have power at the trailer connection. You can google for a 7 pin wiring diagram image to show you where to check. You can also google for a 2007 Ford F53 under hood fuse diagram that will show you where to check.
Perhaps take a step back if you don't find the problem right away, and consider placing a LiFePo4 battery in the toad to power that add-on job independently.
We place a 100 amp hour LiFePo4 on the floor of the back seat of our Ram 2500 Tradesman Crew that pulls our camper to independently power a piezo cooler with our lunch in it as we go out day tripping in it away from the camper.
Not ever gonna end up in a "no start" circumstance from the cooler depleting our starting battery while we were hiking an area of interest or otherwise spend time parked during the day. Preclusion of potential collateral problems by use of independent source load separation is a superpower!
SO on they typical 7 trailer harness connection there is a power lead. I have installed a 12dc charger under the hood of our toad. No dead batteries
May be a fuse n the charge line where it is connected to the toad battery as well. We have a blue ox setup on our Cherokee and there is a fuse at the battery connection.
That is probable the best place to start checking. Work from the end of the circuit to the source.
All good ideas. I will start with the fuse at the towed vehicle battery (Stayinplay braking system) and work my way to the motorhome chassis battery fuses. I'm very confused about the diagrams and fuse descriptions that are in the owner's manual. There is also a fuse box on the wall on the driver's side. Wondering if that might be where the fuse is located.
First, I would question why the battery is dead after only 4 hours and fix the drain on the battery. I know nothing about the braking system you are using, but it should not drain a battery completely down in 4 hours. Next, I would go to whatever store you prefer and gat a handheld jump start unit. Make sure it is big enough to start the coach also. They come in very handy sometimes, can even help out someone else.
If the brake unit is similar to the Brake Buddy, put in front of the seat to push the brake pedal, could it have been that the pedal was pushed a bit forward during setup for that day's tow, and the brake light switch had the brake lights energized the entire time?
You would not expect LED tail lights to flatten a battery in four hours. A quad set of 1157 or similar filament bulbs might pull down a marginal life temaining battery to a no start condition in that time. Alternately, If the brake unit uses a 12 volt powered compressor, a pneumatic leak could make the compressor run too much and easily flatten a battery that was not being kept up by the 12 volt conductor from the coach that was pulling the toad.
I have the Stainplay system mounted under the hood. I checked the 20A fuse and it is good. The Stayinplay is brand new so not likely to have a leak. More tests to come when I get some time. Next test will be to check that the wire from the fuse to the tow vehicle's power plug in did not come loose and if that is ok then I will remove the receiver at the back of the coach, if it can be easily removed, just to make sure that all the wires are connected. Doesn't help any that I'm not mechanically or electrically inclined.
You don't have to already be familiar to have a go at figuring it out - everyone here is rootin' for ya and offering ideas.
After you whip this problem, the best and nearest available experienced fixit resource for toad troubleshooting on this type of problem will be riding in your coach, ready for the next challenge!
Go thru as many of the steps that you can do. Figuring out what is NOT the problem as you have done some of already can be clumsy and tedious, but necessary. You WILL succeed!
You do not have to remove the receiver to test. This should be the first test. You always start at the source of the power and work out. Then move on to the charge wire and fuse. Get a 12v test light, ground the clip and probe the 12v supply pin. 90% of the time the coach needs to be running to power that contact.
