BigRig
- Sep 8, 2024
- Virginia Beach, VA
- Ventana 4037
- 40'
- Freightliner
- n/A
Two-part question regarding hot water heater.
1. Turned hot water heater switch on and not getting hot water (electric mode). Any trouble shooting tips appreciated. I did check the breaker and also, it's not in "bypass" from winterization. There is no hot water at the pressure relief valve.
2. It appears that the water heater is setup to run off of propane also. I have never fired it up that way. How is propane ignition accomplished?
Attached is photo of unit in 2019 Newmar Ventana 4037.
Thanks!!
Thanks!!
