RobertE
- Apr 22, 2025
- Jacksonville, FL
- Grand Design
- Imagine XLS MKE
I also give the hinges and moving parts a bit of dry silicone lub every once in a while. I have many burned out led bulbs on the roller strip and sometimes think they should be replaced........but not often.The only thing I've ever done is clean it.
All I do during the season is sweep off the top before I roll it up.Not rolling them up wet is the point I'd underline; letting moisture sit in the fabric seems like the quickest way to invite mildew. On the burned-out LEDs, do you find the strip is user-serviceable or is it a replace-the-whole-strip job? I'm in Boise where summers are dry but dust and pollen build up fast, so I'd guess a soft brush before washing matters as much as the wash itself. Curious how often you actually clean yours.
