Tip What if something happens to you traveling alone in your RV?
We learned from a fellow boon docker when we first began that if you are having a serious medical issue and can't call for help yourself, then you need to lean on your horn, set your 4 way flashers on and hope your nearest neighbor understands what it all means. If you understand the signal, you will attend ASAP to see what assistance you can be. If an ambulance needs to be called, get it done even if it means driving the where a cell signal exists then wait for the ambulance to arrive and let them follow you to where the patient will be. I would follow the same protocol if I were in a campground.
All of that could be triggered by a bluetooth radio so you don't need to run around the coach while you are down and almost out.
SPOT is a quality unit.
I plan to go out in a flaming heap so someone is going to know........
I have a Garmin inReach Mini 2, the latest now is the 3. A bit pricey but worth it also for RVing in places there is no cellular and you don't use Starlink. This could be your only option of sending messages, etc.
Garmin inReach Mini 3
