Question Honda CRV towed [toad] brake system?
rvkev
Barth Regency [Only about 175 Regencies were made]
Youngstown, Ohio
Barth
Regency
89-Gillig
3208 Caterpillar
Honda CRV
I searched around here a little bit. I am not sure I am using the right keywords.
I want to install a braking system on my 2014 Honda CRV. The brake systems that set on the floor would be difficult for me to remove and install, with my back condition.
I am looking for some sort of system activated by the air Brakes on my BaRTH coach or by some type of surge system.
A permanent system connecting to the master cylinder or brake pedal that does not interfere with normal driving is what I am looking for. I had seen these on other vehicles. The units are permanent and only need to be plugged into the coaches air system or surge system.
The system should also have break-away capability
The Demco Air Force One system meets your needs. I have it on one of my toads. IMO, it’s the best there is.
This is helpful, I have the same question on braking, looking into various systems and I don't want to be man-handling one of those bulky floor units!
I think my rig may have come with this? Looking at eTrailer I recognize a little air tank I otherwise haven't been able to identify, connected to a rear-facing air connection. I'll start another thread to get the details on it.
Neemer, What other systems have you tried?
In my other toad, I use a Roadmaster Even Brake. It’s a portable system that you put in and take out after each use. I’m on my third one of those in 15 yrs. They seem to have a limited lifespan.
We used the Demco stay and play - same as the Air Force one just electric.
Had it in both toads and never an issue with either one.
That is called a "Ping Tank", or "Auxillary" tank that is pre-installed on many coaches for just this purpose; running the Air Force One's air activated system.
If your Bio panel is correct/up to date, you're running a Spartan chassis, and they are the ones who have been installing those from factory for quite some time.
