justin2882
- Nov 8, 2026
Hi everyone, I have a bit of a question. This is my hot water heater. Its a 6 gallon propane one, with a electric ignition system. Atwood GC6AA-8E specifically. Its been failing more and more over time. The last couple of weeks, it has been essentially useless.
2 years ago when I bought the trailer, it would sometimes keep the water hot at a conistent tempature. Most of the time, I would flick the interior switch off then on again. the switch would light up till ignition, then it would then spend ~30min heating the water all the way up before shutting off. Over time, it has become worse. As of 3 weeks ago, the light had not turned on in a very long time. It never kept itself hot and always required being turned off then on. Sometimes it would be tempermental and refuse to turn on, and usually wouldn't heat the water all the way like it used to.
1-2 weeks ago, it suddenly started shutting off after 5-7 minutes and refusing to even try and ignite again until 30 minutes to 2 hours later. I endured a week or two of cold showers before getting fed up and started to mess with it.
I began messing with it. I figured it was the primary thermostat first, so did a temporary bypass with a mechanical winding timer, as the safest jerry rigged option I could think of, without turning the water heater into a bomb lol. I didn't really trust the saftey's on it. That didn't work. Bypassed the saftey 160F thermostat. That seemed like it worked at first? But then shut off early and refused to turn on again. I took the timer out of the loop entirely and tested it without thermostat or timer. This worked? That was a couple hours ago. It stayed on for 15 minutes, with me sitting there watching it. Turned off once at 7 minutes, then turned itself right back on. I had thought it was the brains, ie the black control box in the upper right. If it turns on with me watching it for 20 minutes again tommorow morning I will assume its the thermostats? Otherwise, im tempted to say I need a new control board. I'm not sure though. It could also be the burner tube? All the wires are clean, I checked everything for corrosion and rust. Cleaned the corrosion off the thermostats (and replaced the female plugs which were corroded), everything else was fine.
I included pics of the original setup, my jerry-rigged timer solution, and the control board.
Does anyone have any ideas or diagnosis for this thing?
