NEW TPMS SYSTEM
Jabber Jaw
St. Augustine Fl
Canyon Star 3710
Ford F-53, 26,000GVWR
Ford V-10
2017 Gmc Terrain & 2017 Chevrolet Colorado ZR-2
Hi Y'all,
I bought a 24' enclosed trailer, in which to carry my classic car (1966 Pontiac GTO, if you're interested).
My question is about some of the "new" wirless TPMS units in the marketplace. I had a TST 507 , 10 sensor system with my Newmar.
These new ones are rather inexpensive, with both "solar" & "usb charging" systems. They claim at least an 80' transmission range.
Has anyone used or had experience with these new style "TPMS" systems? If so, I would appreciate your opinion, good, or especially bad, & why!
Amazon has several available......RELVO.......&......TYMATE are two that I looked at. RRELVO does not have replacable batteries in the sensors, which I do not care for. But at the price, one could almost throw it away & buy another! TYMATE does have replaceable batteries, like the TST 507 sensors!
Yhanks for your help and advice!
Allan Bishop
IMHO, only flow through valve caps would be acceptable! Otherwise, you lose pressure each time you need to check other fill through the valve stem.
If the models you mentioned have that, you have my blessing. :)
Hi Y'all,
Allan Bishop
I have the Timate. Recommended to be used only with steel valve stems. (Okay for the coach but not the Wrangler. But seems to work okay with the jeep). My BIG concern was presetting the air pressures. My tire shop set the coach pressures at 90 PSI. When installed the TPMS they read 100 PSI. I purchased tire a pressure gauge from Amazon and it read 95 PSI!! Which is correct?? I went to another tire shop and his read 90 PSI so I just left the TPMS at reading 100. So far no issues other than I had set the high pressure max at 99 (10% of 90) so when traveling, and the pressures exceed 100 I get an alarm. I just hit the mute button and keep an eye on them. I will reprogram sometime. The jeep rides along with no issues. Set at 40 PSI and reads 40 PSI. Oh and I did not have to install the included repeater. No problem monitoring the Jeep.
I've tried TST, Tire Minder, and two different Amazon Chinesium brands on motorcycles, cargo trailers, and RVs. So far, only the TST has lasted, so now I have that on everything.
Haven’t heard of the new one but the TST worked well for us over the years.
Last one is the new monitor with the repeater.
Readings always matched the gauges so I used that to check tire pressures before traveling.
Didn’t have the flow through but no issues getting them in or off and losing air.
Didn’t have to order metal valve stems for the Cherokee since Jeep does not carry them.
Even though the “non flow through” say they can use rubber valve stems I’d go with metal - had one in the first coach that cracked with the extra weight of the cap style monitor.
We have used a TST system for a few years and liked it. We needed more sensors and for the price of adding the sensors for the TST we instead purchased a new complete GUTA system from Amazon that claimed a longer reach.
The new system worked fine for us for our couple small trips, no issues. And the pressures aligned within a couple PSI against our Milton inflator gauge.
We don’t use the flow through sensors, but stick with the sensors we have to remove each time air is needed.
I took all my cheap ones off because I discovered that they were the reason my tires were deflating. I had 3 of the cheap ones on the Goldwing, trailer behind it, and my Jeep. The TireTrakker in my Class C came from the TT I had and I bought 2 extra senders. Only complaint is it seems to eat batteries but generally it works.
As I said....I used "TST 507" for years, never an issue. I have an expensive tire pressure gauge, which was within one "psi" of the TST system.
For the price, I think I'm going to try the "RELVO" system, & compare to my tire pressure gauge.
Once you have tested it, I would like to know your thoughts. If they are positive, I'd like to know w hat tire gauge did you got please.
Will do. But won't be back in Florida til after New Years. Probably be sometime late January, before I'll use the trailer!
Pretty good reviews is the only reason it got my attention!
Enjoy the "Holidays"!
Allan
I've used the TireMinder for well over 10 years with no issues, until this year, when I was ready to head out for a month-long trip. The monitor would not power up. This unit had the micro-USB plug (which I always disliked). I contacted TireMinder and ordered a replacement for $99 (requesting the USB-C plug) and received it within a few days. It was the USB-C connector. Very pleased, and it worked flawlessly on our trip.
I've never lost even ONE PSI screwing the valve cap back on my TireMinder after setting up the initial pressure. I worried about that initially when I set it up, but over 10+ years of use...it's never been an issue whatsoever.
My issue with them was they changed something, maybe comm methods, at some point and obsoleted my sensors. They were supposed to come out with an updated app for the Android, and at one point they shared a beta version of the app that worked fine, but it expired and they never followed through on it, so I had to find someone that was more "product revision stable".
So I just did a search and found that TireMinder and TireTrakker are identical and made in the same Chinese factory.
Agreed. On the Jeep's rubber valve stems, I'd rather have the "relatively" low (and centered) center-of-gravity of the ones that have to be removed to fill. I don't lose much air when putting them on since I'm reasonably quick about it. Knowing how much air I have to let out when using a bleed button, the loss would be negligible at best. While the pass-through ones are easy to use, the weight is even higher on the stem, and off-center due to the design. Not ideal, IMHO.
MY 2020 35' VTDP came with the TT system from the previous owner. The head unit on the TT system was awful. It was mounted in the middle of the MH, and struggled to read the duals consistently. And who wants it back by the bathroom?!? I want it on the dash where I can see it! One of the first things I bought after the cross-country trip home was the TireMinder10.
The TT sending units seem to be identical to the TireMinder10 that I bought to replace the TT system. The TM head unit even recognizes them. Yay for me- now I have 10 spares! The BIG difference was the head unit. A LOT more info on the screen, AND it easily sees all of the sensors on the MH- from the dashboard! I put the wireless extender in the rearmost compartment with the chassis batteries to keep the readings from the Jeep stable. This also made it easy to get power to the extender.
