Question Will a half ton V8 tow 7,000 easily up mountains in Colorado?
kborgs
I've got a 7,000 lb tow behind camper. I'm looking to buy a V8 half ton or 3/4 ton pickup to tow it. Wondering if the half ton is enough to get it up Colorado mountain passes easily?
Easily is relative, but I wouldn't recommend it if it's going to be a regular thing. If it's a one off, then you'd just need to take your time and have good brake controller which you can manually engage.
Vehicles are a sum of their parts.
Engine size, transmission, rear-ended gearing. And yes even age. It's not the age as much as the HP and torque that were available for specific engines for that year and model.
My Jayco was just under 7000 and it was considered a 3/4 ton truck model. I had a 1 ton so no problem. But I have seen some scary 1/2 ton lash ups out on the highway. Its not if it will tow it, it will. But will it stop it? Will you lose control in a tough handling/braking situation? I have towed lots of loads with my 1/2 tons over the years but not at speed and not up and down mountains.
Nope
Is 7000 lbs the trailer dry weight or the GVWR?
I've towed all the major passes in Colorado. A v8 gasser like a Ford 7.3L will do it but with a couple down falls. It will be way up in the RPMs to make the power needed. It will empty your wallet in fuel consumption. And the biggest for me is the lack of an exhaust brake coming down the back side.
Get a diesel and you will enjoy it much better. Love mine in the hig hills towing 12k.
Dropping down Wolf Creek or Monarch or vail without touching the brakes once is a real nice feeling.
The question in the title asks one thing:
Will a half ton V8 tow 7,000 easily up mountains in Colorado?​
What year is your truck? What engine? What rear-end ratio?
You've asked a question with lack of information making it impossible to answer. Newer half-tons, possibly. But if you're talking about a 10 or 15-year old half-ton, I'd recommend against it.
But then you state:
I'd recommend a 3/4 ton, especially through the mountains.
I wouldn't buy a modern diesel for the occasional trip towing, say ~7000-9000 lbs. Only if someone were towing frequently or towing over 12k lbs.
Modern diesels like to work. Short trips, especially unloaded, will kill them. They'll also burn a ton of fuel due to being in regen all the time.
I would go 3/4 ton. There's no modern half ton I can recommend from a reliability standpoint. They're not really built for that kind of work any more.
