Question Will a half ton V8 tow 7,000 easily up mountains in Colorado?
How fast do you normally go around hairpin turns in a ~15k pound GCW rig?
I've had many wdh's o
One problem with a half ton is that you will probably be using a weight distribution hitch with this combo. WD hitches are dangerous going around hairpin turns, so you have to slow way down to keep your rig from jackknifing. You won't need the WD hitch with a 3/4 ton truck.
I've had many wdh's on numerous trucks over the years and never a problem with even the tightest corners.
Common sense! That's right! They are all unsafe without it.
I have spent many seasons in the Rockies and never had anything but gas run vehicles. My 1/2 ton truck has 154000 miles on it, it's a 2016(yup 10 years old. Last one retired at 22 years old and 230000 with same trailer and a smaller engine, same duty cycle) has a 5.7l engine. Most all the miles 50% of the time has hauled trailers over that 7000 lbs you asked about.
My granddaddy told me start the downhill trek at the speed that you can crest the same grade at. He never drove a truck. He never had more than a straight 6 under the hood. And yes he pulled trailers.
The disappointment is that the kind of common sense that that generation had is truly possessed by less than.01 % of the current generation.
That said! Maybe a 5 tonner would be in order. That might keep your family safe, but everyone else would be advised to stay off the road, if you don't possess that common sense I talk about.
To answer the question seriously? 1/2 ton truck will handle 7000 lbs if it was engineered to handle the load. Common sense will make travel much safer than many one tons on the highways tonight.
The statement above is not a license to fudge the spec's.
Even if Kevin and I have on quite a few occasions. Please apply common sense. OR you will crash and die in a ball of fire.....at least that is what all the forum expert have been warning everyone for years that dare exceed the limits by 5 lbs. Or go to fast on trailer tires rated for a Honda Civic.....Etc.
They'll also burn a ton of fuel due to being in regen all the time.
Not sure about that fact. I average about 14mpg towing and my truck very rairly regens when you use it.
Same truck towing same weight with a gas engine would probably get around 8mpg...
I'd rather not listen to a gas engine scream at me around 4000rpms climbing the same grade mine handles at about 2000rpm. And as noted the exhaust brake is a game changer for me in the steep grades..... but thats just me.
Any regular towing I would have a 3/4 ton. I towed with both. 3/4 ton and a towing set up and you will be pleased.
There is arguably no such thing as a 1/2 ton or 3/4 ton pickup, and there hasn't been for decades. There's also no such thing as "an F-150" or "a 1500", because it all depends on the Max packages, wheelbase, cab size, engine size, rear-end, 2 vs. 4 WD, and hitch installed. Towing capacity swings from 7K to 12K depending on all those things.
But, it sure makes for lively discussion on Internet forums, and you'll get anything from "I've done it for years" to "You need an F-950 or you'll die in a fiery crash". Somewhere in the middle is your comfort level, and only you can tell what that is. But I do recommend not going too far over the engineering tolerances. Keep it safe out there.
Now, who wants to talk about the best oil to use in our engines? ;)
Maybe this should fall under a different thread.
I'm no petroleum engineer or mechanic but, IMO, it's the most important component of the engine 'cause without it, you don't get to go very far. I have, for as long as I can remember when synthetics came out, used Mobile 1 full synthetic and changed every 10,000 K (roughly every 6000 miles). The same formula goes for the Jeep and the coach. The coach is a pavement princess so highways only and usually three hour drives. It does not work hard hill climbing nor do we exceed our towing limits. The Jeep does play in the desert, does some four wheel off roading but not overly serious stuff. It is mostly touring and grocery getting.
I have never heard anyone say they have too much truck.
When towing. Not so much when used as a daily driver.
Both conditions need consideration. Full timers are the least likely to complain in a parking lot. Others may think they have to much truck if they have only a truck.
As a full timer, I can attest to the fact I have complained when in a modern parking lot.
