RV roof strength
Old one
Altamonte Springs, Fl
I have another question. I desire having a built on ladder in whatever RV I buy, for all p
practical purposes, I am alone, for ease of cleaning and inspecting. Some of the RVs have one installed at the factory; some do not. I think it would be easy to aftermarket one, however, should I be concerned about the roof safely supporting an 180# man?
I looks close to buying one now.
Typically if the unit does not come with a ladder or a ladder attachment point (have to by the ladder separate that hooks in) then yhe roof is not engineered to be walked on.
For years, we said if it came with a ladder you could probably walk on it, and if it didn't, you couldn't.
COVID supply chain restrictions meant more units shipped with walkable roofs and no ladder, and some manufacturers got used to the idea of not providing one after that, so it's not the hard and fast rule it used to be.
Best bet is start near the edge on all fours, go from there.
Not factual. On Newmars, the Dutch Star and up do not come with ladders due to rear cap design. Nothing to do with the strength of the roof. More and more manufacturers are getting rid of kadders for liabilty reasons.
Our 2019 Jayco was ordered with a ladder delete. When we purchased it, I asked our dealer to install one and it could not be done as there were no reinforcements for the anchors. I suggested an After Market. They would not do it as they could not guarantee it would hold any weight. I have a telescoping ladder that works fine. It stores easily and isn't all that heavy. It is awkward moving it while extended though.
I have seen more than one RV roof leak because the ladder roof mounting worked loose.
Never saw a roof suffer because I walked on it! You weigh less than I have weighed in 20 years.
Most just carry a collapsible ladder, and that is the only recommendation I have for you.
Our 2018 Coachmen Freedom Express travel trailer is specifically called out as having a walkable roof in the brochure. There is no option to purchase one with a ladder on it.
I carry a task ladder in the truck when we travel.
It's not the roof strength that's the issue. As one of the posts pointed out generally all RV roofs have to be walkable for the exact reason the post mentioned, replacing hardware and maintenance such as sealing. But, ladder or not is associated with wall bracing or studs in the rear wall build to attach the ladder to.
If your rig didn't come with a ladder , chances are high you don't have the bracing, so you can't aftermarket add a ladder. There's nothing to attach it to
This is exactly what Jayco told me about my 2011 when I contacted them about it. I had acquired a ladder thru work and wanted to mount it. I ended up selling it.
That is not necessarily a true statement. None of the Quality DP Class A's (Newmar, Tiffin, and American Coach) have ladders, but the all have rooftop AC's and other things on the roof that require periodic maintenance. No, they are not made to party on, but they are certainly made to walk on for routine maintenance.
If you couldn't walk on it, snow loads would collapse it, of course you can walk on it
