Joined club lost Freightliner hub cover
I think @MapNerd recently had this happen and I noticed several loose after my service at Gaffney in May. I just pushed them on hoping they'd stay. Well, one is missing, $90 spent, new one on the way.
Oh, that is ugly! I can see why you won't be able to drive the Ventessex another foot until that naked hub is fully clothed again. Miss Elli must be mortified! :ROFLMAO: :ROFLMAO: :ROFLMAO:
I hated those hub covers on our Ventana LE; they were always loose. I considered taking them all off, but a good bead of silicone caulk helped lock them in place.
Yep. Learned that lesson. Took the advice of others and put a bead of silicone on the steer and tag hub caps. Ordered replacements here Hubcaps & Wheel Covers
I lost three before I smartened up and started using silicone to hold it. DON’T buy them from Newmar.
Price was 89 from Newmar which includes shipping. Link above was same pricing. Will silicone when new one comes and before next departure.
NINETY BUCKS???!!!!! :oops: :oops: :oops:
shocked baby GIF
I also have to silicon the grommets in the wheels for the tire valve extensions. They never stay in place otherwise.
You do have a solution in hand for that problem. Just saying. :ROFLMAO:
I went around the entire perimeter of the cap.
Interesting how this thing even stays on. Just got it today, haven't installed it yet.
I'm guessing after a few remove and reinstalls those tabs get bent in the wrong direction. Probably needs remove and inspect after a service.
Actually, I think the flange the grippers are attached to get bent inward, lessening the tab pressure holding the cap in place. I suspect that they only go on and off a couple of times before that starts to happen.
I lost a front cover about a year ago. Newmar wanted $110, local Freightliner shop was $25.
