Yes, it’s a Dometic. I’ve changed the sail switch. I’ve made sure the propane is good by lighting the stove top and water heater. It will come on, ignight for a few seconds then the burner will go out and the fan runs. It will oscillate like that until the room temperature is met.IF you have access and are comfortable doing so try cleaning the igniter and burner. Was the furnace functioning prior to this problem?
Thanks great advice. It was a low propane output from the regulator.The burner on an RV furnace has a spark ignition (no pilot flame). The burner lights with full flame and the spark rod is then used for flame rectification. In other words, when the burner first tries to light the rod throws a spark to the burner and lighting the propane, then after the gas valve opens the spark rod is used to sense flame by using the flame to conduct electricity. If the spark rod is dirty you may or may not see the anything wrong with it, but use a scrubber pad to clean it to a nice shine. When the burner does light is the flame nice and strong and mostly blue in color? If it has yellow in it the burner itself may be partially plugged (spiders are good for this) or I have seen an orifice get partially plugged. Use nothing stronger than a toothpick to poke the hole in it. Also, you can have a board fail on it and it will act like that. My water heater did pretty much the same thing. I purchased a Dinosaur Board through Amazon and fixed it. HERE is a site that has some good troubleshooting instructions.
Please start a new thread so people see the results.Now we’re working on the toilet that will not seal after flushing.
