- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I can't stand little noises while driving, I already switched from glassware to acrylic drinking glasses and that fixed that issue. There was a knocking noise in the left pillar left of the windshield and when my windshield was replaced last December Newmar secured the wire bundle running up there and solved that problem. I've been hearing an annoying knocking in the right side pillar and today decided to fix that one up. Not sure why Newmar didn't do the right side. Anyways there's a pretty heavy bundle of wires zip tied going up the right side so I used gorilla tape in several areas to tape it to the back wall so it can't move and knock. I also have to look at the rubbing of the pillar against the dash as that plastic on plastic likes to make noise as it flexes. I may stuff some velcro in there to pad it like Newmar did on the mesh shade.
So if you have noises in those pillars it's the wire bundles going up that path. Easy to fix.
